Which is lighter ABS plastic or Fiberglass . 6 PAC #531454
11/19/09 10:51 PM
11/19/09 10:51 PM
Wi.
65_gt_rag_402 Offline OP
Wi.
Which mopar 6 pac Hood scoop 5 inch tall is lighter . ABS plastic or Fiberglass ?
Looking for a different look on my dart . I have an issue with air cleaner to scoop clearance . The Air cleaner is right up to the top of the hood scoop. also not much around the side clearance either. I'm thinking about a 6 pac 5 inch tall for the dart.
Thanks !
65 DART GT RAGTOP mopars "AWESOME" 360 magnum stoker 402 Engine !!!!!!! ROCKS !!!!!!!!!! 11.0's on pump gas .
Re: Which is lighter ABS plastic or Fiberglass . 6 PAC [Re: 65_gt_rag_402] #531455
11/19/09 11:04 PM
11/19/09 11:04 PM
Florida STAYcation
dOc … Online penguin-006
The village idiot's idiot
dOc …  Online Penguin-006
Florida STAYcation
If you are given a choice ... ALWAYS go with fiberglass. It is more durable ...and when exposed to the UV and the heat of the sun and engine heat .. the fiberglass will actually cure more .. when the plastic actually is "hurt" by the same.
