Deciphering factory frame diagram #530210
11/18/09 09:43 PM
11/18/09 09:43 PM
MN
58pwrwgn Offline OP
58pwrwgn  Offline OP
MN
I am trying to figure out what the points A & B represent in the frame diagram. I am assuming it is the leading and trailing edge of the K frame above the torsion bar center line but I am not sure. I attached the diagram.
Re: Deciphering factory frame diagram [Re: 58pwrwgn] #530211
11/18/09 11:40 PM
11/18/09 11:40 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Are they mentioned in text?
They are not ON the frame, but are a point inside the rails and below them....
Re: Deciphering factory frame diagram [Re: RodStRace] #530212
11/19/09 12:11 AM
11/19/09 12:11 AM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I took a class in blueprint reading and dimensioning and I cant figure it out! It MAY be the torsion bar locations (?) but I dont know if they are about that distance apart. 33.92 is the bolt center distance for the K member, what I really dont get is the lower drawing dimension .70 below frame centerline and then the 1.74 below frame CL measurement that looks to be a parallel line (torsion bar under Frame CL?) Do the torsion bars rise toward the front? Looks too high to me.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: Deciphering factory frame diagram [Re: pishta] #530213
11/19/09 12:28 AM
11/19/09 12:28 AM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
are they the c/l location for the lower control arm pin location? which should be in line with the LCA strut rod hole at the front of the frame? Just throwing stuff out there.
Re: Deciphering factory frame diagram [Re: 58pwrwgn] #530214
11/19/09 10:39 AM
11/19/09 10:39 AM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Those are the Torsion bar centerlines!(Front Spring)
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
