Re: Intake porting?
[Re: mopowers]
#527362
11/16/09 12:27 AM
11/16/09 12:27 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
On that engine I'd say around 20HP.
Brian Hafliger
Re: Intake porting?
[Re: Brian Hafliger]
#527363
11/16/09 02:35 AM
11/16/09 02:35 AM
Posts: 3,749 Chowchilla,ca
Chassisman
Chowchilla,ca
so how much is my 500 ish pump gas ported -1 motor gonna make? ...looking like Dec4th I'll be droppin it off.Got business on the 5th in Hollywood.
Re: Intake porting?
#527364
11/16/09 10:31 AM
11/16/09 10:31 AM
Posts: 3,441 Mo.
supercomp
Mo.
What would it do for our B1? The heads are coming soon as we get them pulled.
Re: Intake porting?
[Re: supercomp]
#527365
11/16/09 12:38 PM
11/16/09 12:38 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
It all depends on how bad the intake is before porting....! If an intake is poor OOTB you can really look like a porting HERO by making more than that but reality if the intake is really good OOTB and you pick up 10HP you look like a HERO's backside...LOL! The higher HP the engine the larger the gain (usually) because your working on a larger scale.
I've seen upwards of 35HP gain with Indy's 4500 intake when modified. That was on a 700Hp engine.
Brian Hafliger
Re: Intake porting?
[Re: sg66mopar]
#527368
11/16/09 03:18 PM
11/16/09 03:18 PM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
Mopower: plenum and runner porting can be time consuming but that intake is a nice OOTB casting and is not too bad. SG66: Scott's right, the B1 intake is nice OOTB and I usually only port the runner exits and some mild blending at the plenum.
Brian Hafliger
Re: Intake porting?
[Re: sg66mopar]
#527369
11/16/09 03:27 PM
11/16/09 03:27 PM
Posts: 3,441 Mo.
supercomp
Mo.
I have a set of B1s coming from Koffels. Scott said it's not worth the money to get carried away unless you want every last HP. My motor's pretty big in a fairly light car and I only want to run around 8.60 so they're just going to bo a basic clean up and port match.
Yeh,we'll probably leave it as is,just port matched to our cnc heads. I just can't leave anything alone.
Re: Intake porting?
#527370
11/17/09 12:06 AM
11/17/09 12:06 AM
Posts: 3,011 Sac, CA
mopowers
Sac, CA
Thanks Brian.
I'll probably just port match it my self and blend the runners
I have noticed though if I place a carb gasket on top of my Victor's carb flange, there is quite a bit of material to the inside of it. Would it be wise to remove these "bumps" to open up the plenum a little?
Maybe I should post a picture...
Re: Intake porting?
[Re: S/ST 3040]
#527372
11/17/09 12:29 AM
11/17/09 12:29 AM
Posts: 5,486 SoCal
Brian Hafliger
SoCal
eeeewwwwweeeee...I've seen that before...LOL!
Re: Intake porting?
[Re: mopowers]
#527376
11/17/09 08:56 AM
11/17/09 08:56 AM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
Did it pick up any with that work you did?
I would say it did although it was never tested before. That's a fairly standard modification to the Mopar Victor series intakes. Like doing a valve job on new heads before they are used.
Re: Intake porting?
[Re: mopowers]
#527377
11/17/09 09:48 AM
11/17/09 09:48 AM
BradH
FWIW, I did the same mod to a 440 Victor which showed about 8-10 HP increase on the dyno at higher RPM compared to an out-of-the-box one.
Re: Intake porting?
[Re: Cyl.Porter]
#527380
11/18/09 07:49 AM
11/18/09 07:49 AM
Posts: 877 ky
68roadrunner
ky
I did an old M1 manifold on a 540ci.street motor and it made 654hp and 704lbs torque on the dyno. It had fully ported closed chambered eddy's. I think you can gain 35+ horse with the manifold ported. But it all depends on what cam u are runnig. The 540 was a full roller with cross bolted mains. We tested three manifolds and all three were in the 630+ range. M1, Wiend Tunnel Ram and a 6-Pack. If you have any questions feel free to give me a call. 1-712-790-6106 and ask for jason(Shotties Porting Service).
i was wondering what the cam would play into, on porting the intake. with the cam i run, we believe it must have more reversion than others. so would porting the intake help more or less? i run indy -3 with -1 heads cnc ported to 325
