Re: New MOPAR 5 speed from McLeod!!!!!!!
[Re: fstfish66]
#517420
03/18/10 06:13 PM
03/18/10 06:13 PM
Posts: 1,212 QLD Australia
Keith Black®
QLD Australia
these guys supply a hydraulic clutch master cylinder & linkage kit. I've just ordered one (it's impossible to order from Keisler or those that offer "complete kits" - my experience was unless you're ordering the whole system you are priority No. 62,342). http://www.hotrodhydraulics.com/Mopar-Product.htm#HYDRAMAX™ Master Cylinder Kit
-------------------------------- Darren Beale Keith Black Racing Engines®
[Re: Keith Black®]
#517421
03/18/10 08:41 PM
03/18/10 08:41 PM
Posts: 301 wisconsin
swifter
wisconsin
Listen up men::After recently having to pull my ol'833 three times because of seal failing in my brand new hydrolic t.o. bearing from this new 5 speed supplier I would really think twice about rushing out because of a price tag!!!! welcome to the world of human guinni pigs--Any wait on Jamie's 5 speed is well worth it--All you have to do is meet Jaime in person (as i did last year at nats) and you find out he is a genuine trany guru and will stand behind any product he sells--His knowledge is spot on and I'm sure he would not put his name on anything unless it was top notch.Cost more yes of coarse it will, but in this day someone who is investing his time and money to release a AMERICAN MADE ITEM should be applauded for his efforts.GO JAMIE GO --Steve
2007 Ram 2500 Cummins
2008 Dodge Nitro
1970 340 Valiant Duster
[Re: Keith Black®]
#517422
03/19/10 01:06 AM
03/19/10 01:06 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
yikes,, so sad,,but so true,,,was funny reading,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: Keith Black®]
#517424
03/19/10 08:27 AM
03/19/10 08:27 AM
Posts: 211 Tennessee
Keisler Sales
Tennessee
We have no problem selling the master assembly I don't offer a A833 throw out bearing.
Keisler Engineering www.keislerauto.com#1 Choice of Overdrive Transmissions with Over 14,000 Sold
[Re: JamiePasson]
#517425
03/22/10 06:25 AM
03/22/10 06:25 AM
Posts: 4,862 the frozen wastes...
Pale_Roader
Swears too much
Swears too much
The McLeod unit is still up in the air by the sounds ov things. But the price is at least decent. And really, i could give a [Edited by Moparts - Family Friendly Site - Keep it clean] where it was made as long as the quality is there. China doesn't necessarily mean junk, just like homebuilt doesn't necessarily mean quality.
The Passon 5spd again, outta my budget, no matter how good it is. And personally, not a fan ov the 4spd OD idea, drove one (a stock truck unit in a 340 Demon), and just did NOT like the gear spread. I wouldn't even want that in a 440 car where the torque could mitigate the disadvantage.
See, this is where you are wrong. Our 4 spd OD gearset isn't even close to the gearset in the truck trans that you drove in the Demon. I don't feel that you are giving that option a fair shake.
As for the imported thing, that is entirely your call. The unit is actually made in Korea, not China. If it doesn't matter to you that it is imported, that is fine, it sounds like it should fit what you need and it will fit into your budget. What kind of horsepower did you have? Thanks, Jamie
We are looking at less then 5 grand for this unit.
*fixed your quote for you Jamie
Whoa, maybe i should check back more than once a month here... heh heh...
My bad, i didn't know the one you offer wasn't a superwide spread like the truck unit. Thing is, i liked that 1st gear, especially since both my temp engine for this project and the final engine will be high-RPM, lower torque engines (thinking 383-426 N/A lowdecks, both). I liked the steep 1st, i just didn't like the spread. The owner didn't seem to mind, nor did the guy who installed it, but that would bug the hell outta me... like shifting from 1st to 3rd in a race... ugh.
Your 4speed has a nicer spread, but its still a bit wide for my taste. Its great that others like it, its just not for me. I like that 1:1 4th. I really just want 5-6 gears in my box. Maybe if i could actually drive one i might like it? i could be that far off base...???
Even the 5-speed would get old for me i think. The engine i build will want at least a 4.56 gear, but i want a 2.76 for the road. I know... i really dont want much... haha. Really, i want a 6-speed. I'd go with a 5, but after spending all the money it will take go buy any one ov these kits, i'll still be thinking ov that 6th gear, the one that turns my 4.56's (or more) into a real highway gear.
Really, it just kinda bugs me that with all these cheap (say, Cobra-spec... which are plenty strong) T-56's out there i still cant easily bolt one up to my big block.
Oh, and not sure which engine you are asking about, but the 'temp' one going in my car will be around 400-450HP, maybe a bit more depending on if i can find some cheap aluminum to cover the bores. That 340 in the Demon was pretty hot, probably a bit under 400?
[Re: JamiePasson]
#517426
03/22/10 09:56 AM
03/22/10 09:56 AM
Posts: 8,166 Left Coast
BobR
Left Coast
Well, I was not going to say anything just yet, BUT I feel that in light of the recent buzz about the McLeod trans, I guess it won’t hurt.
For a couple years now, we have been working on a NEW 5 Speed trans for Chrysler cars. We were not aware that McLeod was also doing it.
This is a clean sheet project. In other words, we are building this from the ground up. Due to our extensive experience with the cars that it must fit into, our individual designs that we will be offering will make installation easy. In fact, we feel that it will be something that the average guy can put in their car in just a few hours.
This unit will be a BOLT IN!!!!!!! No monkey business with driveline angles, notching torsion bar crossmembers, redrilling bellhouisngs, changing clutches. You will retain your ORIGINAL shifter handle in the ORIGINAL location. The unit will look like it came from the factory in the car. It will be a HURST style shifter arrangement with external linkage, just like the design of shifter that these great cars left the factory with.
There will be an A Body trans There will be a B Body trans (‘63- ‘69) There will be a'70 - UP B/E Body trans.
You will use your ORIGINAL driveshaft and yoke You will use your ORIGINAL transmission crossmember and trans mount You will use your ORIGINAL bellhousing You will use your ORIGINAL flywheel, You will use your ORIGINAL clutch and throwout bearing (18 spline only)
The unit WILL fit under the floor pan with no modifications.
Due to the simplicity here, it WILL be as easy as changing the trans. Truly an afternoon job.
As for cost… I can tell you this, it will not be $2300.00, HOWEVER, I feel that the price will be fair considering that the unit is MADE for the car. Versus taking an existing trans and trying to shoehorn it in and not cut the car as other manufacturers have tried in the past.
To accomplish the project, we have drawn on the years of gear cutting experience from our partner GFI. This is the organization that we have been working with our very successful Hemi OD project. They have a brand new CNC gear cutting facility that WE will be manufacturing the units.in.
And now for the BEST part…….
IT IS MANUFACTURED IN THE USA!
There will be more to come….
I may be one of the first in line for your E body version. Since I put 4.10 gears in my T/A I no longer enjoy driving it around town. However, I don't want to give up the additional torque multiplication and I don't want to cut my car up. I would like to see a .75 overdrive and a 2.90 first gear. This would be perfect for me.
[Re: Pale_Roader]
#517427
03/22/10 10:00 PM
03/22/10 10:00 PM
fstfish66
levittown pa
wondering if the MC,Leod unit or people will be at chryslers at carlisle,, to show or talk about the tranny,,,,ide like to see it up close,,,
[Re: fstfish66]
#517428
03/22/10 10:34 PM
03/22/10 10:34 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
me too....
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Old School]
#517429
03/22/10 11:42 PM
03/22/10 11:42 PM
fstfish66
levittown pa
me too....
ANY ONE HAVE A CONTACT NUMBER??? from what i have read here MC,LEOD is not part of B&M any longer??? how do we get a hold of red roberts??? ill call and see whats the scoop...
