Re: Turbo Guru's! Air Fuel Ratio #'s
[Re: Twostick]
#515823
11/05/09 10:32 PM
11/05/09 10:32 PM
Posts: 1,325 Orlando Fl
Dos Snails
Orlando Fl
A BOV for a draw-thru system?
Kevin
sure! you vent it into you exhaust pipe then use a igniter to have a flame show ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Dos Snails]
#515824
11/06/09 01:10 PM
11/06/09 01:10 PM
Posts: 173 Tucson AZ
2cudabuck
Tucson AZ
Okay, sorry, wrong term. The valve that is in the exhause feed to the turbo, and is boost referenced, so when you hit a specific boost number, it opens and bypasses the turbo and dumps right into the exhaust. a WASTEGATE !!!!!
Buck
67 273 Dart GT
69 RT 440 Charger (SWEET!)
70 318 Cuda
74 Cuda Packin a 426 roller Hemi
[Re: feets]
#515826
11/09/09 11:31 PM
11/09/09 11:31 PM
Posts: 2,697 Renton Wa
topfueldart
Renton Wa
Do you like your engine? To you like having pistons and head gaskets in that engine?
The boost will spike fast and hard. Unless you're babying the thing you will never be able to control boost with your foot.
No chance of you controlling boost with your foot.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
[Re: jyrki]
#515828
11/10/09 05:31 PM
11/10/09 05:31 PM
Posts: 28,071 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
I forgot about your toy. Good to see it again!
