Re: Turbo Guru's! Air Fuel Ratio #'s [Re: 2cudabuck] #515821
11/05/09 06:41 PM
11/05/09 06:41 PM
Detroit, MI
CokeBottleKid Offline
Detroit, MI
under low low boost it's not a huge deal, but yes you need a BOV.
Re: Turbo Guru's! Air Fuel Ratio #'s [Re: CokeBottleKid] #515822
11/05/09 09:30 PM
11/05/09 09:30 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
A BOV for a draw-thru system?
Kevin
Re: Turbo Guru's! Air Fuel Ratio #'s [Re: Twostick] #515823
11/05/09 10:32 PM
11/05/09 10:32 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
Kevin
sure! you vent it into you exhaust pipe then use a igniter to have a flame show
Re: Turbo Guru's! Air Fuel Ratio #'s [Re: Dos Snails] #515824
11/06/09 01:10 PM
11/06/09 01:10 PM
Tucson AZ
2
2cudabuck Offline OP
Tucson AZ
Okay, sorry, wrong term. The valve that is in the exhause feed to the turbo, and is boost referenced, so when you hit a specific boost number, it opens and bypasses the turbo and dumps right into the exhaust. a WASTEGATE !!!!!
Buck 67 273 Dart GT 69 RT 440 Charger (SWEET!) 70 318 Cuda 74 Cuda Packin a 426 roller Hemi
Re: Turbo Guru's! Air Fuel Ratio #'s [Re: 2cudabuck] #515825
11/09/09 06:17 PM
11/09/09 06:17 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
In my shop right now, lovin wrenchin and lovin life!!!! I have no wastegate. Was just gonna watch the boost gauge real close until I learned the characteristics of my system. Am I nuts?
Do you like your engine? To you like having pistons and head gaskets in that engine?
The boost will spike fast and hard. Unless you're babying the thing you will never be able to control boost with your foot.
Unless you got this turbo off a diesel, it probably has an internal wastegete. Is there no vacuum pod looking thingie like the zinc plated one on the side of this turbo?
- Stu Harmon
Re: Turbo Guru's! Air Fuel Ratio #'s [Re: feets] #515826
11/09/09 11:31 PM
11/09/09 11:31 PM
Renton Wa
topfueldart Offline
topfueldart  Offline
Renton Wa
No chance of you controlling boost with your foot.
11.48 @ 120 with a 1.80 60' 318, stock 1.88 heads, stock 904, Pump Gas, 13 lbs of boost.
9.94 @ 134, 318 on pump gas, 14 lbs w/ Eddies, transbrake 727, 3600 lbs, 3.54 gear and 28's.
Re: Turbo Guru's! Air Fuel Ratio #'s [Re: topfueldart] #515827
11/10/09 05:21 AM
11/10/09 05:21 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
We have about 11.2:1 A/F at WOT. We have 40 degrees of initial spark that will drop to 20 degrees at 29 psi (although we've never been that high). The engine is a BB, 8.6:1, air to air intercooler nad 93 octane. http://www.youtube.com/watch?v=EK50vNlHjLo
Plynouth VIP '67 TT IC EFI
Re: Turbo Guru's! Air Fuel Ratio #'s [Re: jyrki] #515828
11/10/09 05:31 PM
11/10/09 05:31 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I forgot about your toy. Good to see it again!
- Stu Harmon
