Re: 0.800 lift on EZ heads
[Re: JohnRR]
#51513
01/20/08 03:58 AM
01/20/08 03:58 AM
Posts: 633 NY/NJ
DV8
mopar addict
mopar addict
NY/NJ
Whoaaa boy! That is steep! What ratio rocker are you using?
~S~
"The function of man is to live, not exist..."
[Re: 67_Satellite]
#51518
01/20/08 02:17 PM
01/20/08 02:17 PM
Posts: 1,981 SE Michigan
TS3303
SE Michigan
O.K., maybe I missed a previous post or something,but why so much lift? Is this just an exercise to find out how much is possible?
is this an allout max horsepower headsup type engine?
IMO opening the valve that far past the useable range of the intake port is a waste of energy, reduces durability, increases wear on the valve train. not worth the extra 2-5hp that you might get. springs will have a very short life.
[Re: AndyF]
#51522
01/26/08 10:24 PM
01/26/08 10:24 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Andy, is there enough flow at .800 to make it worth your while? I would have figured it stalled by then Its surprising that the tool is strong enough to pop the springs off, I have the same and on my W-9 I have to pull 4 springs per head to get to the head studs
[Re: AndyF]
#51524
01/27/08 06:58 PM
01/27/08 06:58 PM
Posts: 43,223 Bend,OR USA
Cab_Burge
I think a lot of people forget that a running motor never sees the valve held open very long like a flow bench measure flow at. As Andy said when you lift the valve open more the motor has the opportunity to suck in more air than it does at a lower valve lift for the same duration Now when you introduce valve train components like the Jessel rocker system, single tapered pushrods and the exotic valve materials and super good valve springs why not bump the valves open more Isn't hopping up a motor basically about getting more air and fuel into the motor so it will make more power.(IE: heat via a controlled explosion)
