Re: 11 seconds with a 416
[Re: rt66jim]
#514547
11/06/09 07:10 PM
11/06/09 07:10 PM
Posts: 429 Sherman Texas
The Shocker
Sherman Texas
11.48 with my 408 Dart. Motor: .030 over 360 from a 71 pickup ,stroker crank ,eagle rods ,Kieth Black 10 to 1 pistons,Econo W2's Sharp roller rockers,Edelbrock Performer Rpm (wimp)hydraulic cam,Victor intake,750 Demon ,Hedman Fenderwells,MSD ignition. Trans: Powerglide ,manual valve body,3000 stall. Rearend:8 3/4 from the same 71 pickup that the block came from ,with 4.10 gears. Suspension and tires: Stock 6 cylinder original springs and torsion bars ,with 15x4 Cragers up front and 15x7 steelies in the back,26x8.5x 15 slicks. Homeade subframe connectors welded in place .I launch at 2500-2600 and shift at 5800.The car has a best of 11.48 in the 1/4 and 7.27 in the 1/8 and has more in it im sure.You can see in this vid how bad its spinning and costing ET off the line..11's should be easy for your 416 build in a street car... http://www.youtube.com/watch?v=BIIyWUefEYQ
[Re: MIKES_DUSTER]
#514551
11/09/09 06:25 PM
11/09/09 06:25 PM
Posts: 2,578 sweden
1Fast340
sweden
Just curious why build and spend the extra money for a stroker to go 11's when a good 360 can do it??
no expert but you can do it with a whole lot less rpm and converter and the motor will live longer and be more fun on the street i gues
[Re: qwkmopardan]
#514552
11/09/09 06:37 PM
11/09/09 06:37 PM
Posts: 1,686 Phoenix, AZ
Comp_Chassis
Phoenix, AZ
Friend of mine and his brother both have 410 strokers both of fairly similar build.
360 blocks, .040 over, 4" cast cranks, eagle rods, JE reverse dome pistons, 11-1 compression, crane hydraulic roller cams, holley strip dominator intakes. 1 engine has the indy modified edelbrock heads and the other is out of the box indy heads.
The std edelbrock head engine is in a 67 Coronet, 3.55 gears, 727 auto, 3000 converter, full interior, battery still in engine compartment, car can be driven any where any time. Drives it to the track, leaves it in drive and on MT street radials it runs 11.70's.
Other car is a 64 Valiant, 904 trans, full cage, bench seat, mini tubbed, 3.91 gears, MT street radials, drives it to the track and has run 11.00 without really being tuned yet. They just switched it to 3.55 gears and have not run it again yet.
[Re: MIKES_DUSTER]
#514553
11/09/09 06:38 PM
11/09/09 06:38 PM
Posts: 883 Affton MO
qwkmopardan
Affton MO
QUOTE "Just curious why build and spend the extra money for a stroker to go 11's when a good 360 can do it??" It only costs a few hundred bucks more to do the 4" crank stroker motor. And the crank is only about $100 more the grinding the 30 year old stock peice. I think it's crazy to not go the stroker route even though I have been 10.20s with a .040 standard stroke 360 at 3100lbs. Now it has run 9.68 at 136 and does this, with a stroker crank 360. Still home ported junkyard heads, 587 castings, .590 flat tappet cam, flat top pistons, and runs on gasoline, 110 octane.
[Re: 73cuda340]
#514554
11/09/09 09:29 PM
11/09/09 09:29 PM
Posts: 11,704 W. Kentucky
justinp61
W. Kentucky
Mines a 408 in a 69 Dart street/strip, 3300#. K-1 steel crank,Comp Star 6.125" H beam rods, Diamond 20 cc dish pistons, ported Edelbrocks, Victor 340, Bigs 950 HP, Hughes flat solid, 260/264 @ .050, .626/.633 lift with 1.6 rockers. With no tuning it ran 6.61 @ 102.24 (1/8) on the only pass I've got it to hook. The compression is only 10.9-1 so I run it on pump 93. It should run mid 10s when it's tuned.
My old hydraulic cammed, pump gas 340 in the same car ran 11.62.
[Re: MIKES_DUSTER]
#514557
11/10/09 12:25 AM
11/10/09 12:25 AM
Posts: 2,141 junction city oregon
viperblue72
11.0@122 with crappy 1.65 60ft. and only 2 passes 3200lb street duster. power steering,power brakes, full exhaust. Driven daily. 408sb 10.7 compression indybrock heads 248/577 comp solid roller victor intake 950 holley 3000 stall 4.10 gears
[Re: viperblue72]
#514558
11/12/09 08:05 PM
11/12/09 08:05 PM
Posts: 1,189 clarks summit pa
73cuda340
clarks summit pa
Any opinions on cams? Im considering either a comp xe275HL or maybe go to a solid with the Comp XS274.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
[Re: viperblue72]
#514560
11/13/09 04:46 PM
11/13/09 04:46 PM
Posts: 498 El Dorado Ca
65signet
El Dorado Ca
You can find something better than comp, there selection for mopar is not good and most of there cams have to much duration for a good street strip car.
1965 Plymouth Barracuda 273 M/SA 1970 Plymouth Duster 360/904 10.60s with J heads
[Re: 73cuda340]
#514561
11/13/09 05:27 PM
11/13/09 05:27 PM
Whats the lift on those cams??...when i first built my 416 i was using only a .494/.513 cam and it put my duster in the 11.20's....
#514562
11/13/09 11:08 PM
11/13/09 11:08 PM
73cuda340
clarks summit pa
Comp XE275HL is 231/237 @ 50 with .525/.525". Comp XS274 is 236/242 @ 50 with .502/.511".
[Re: Triple Threat]
#514564
11/14/09 04:55 PM
11/14/09 04:55 PM
73cuda340
clarks summit pa
How about a 240/246@50 with .507/.510"?
[Re: 73cuda340]
#514565
11/20/09 05:29 PM
11/20/09 05:29 PM
73cuda340
clarks summit pa
Would any of the cams in the 240@50 range still be streetable? I want it to have a nice choppy idle but at the same time I dont want to lose a lot of low end torque.
[Re: 73cuda340]
#514566
11/20/09 06:15 PM
11/20/09 06:15 PM
The Lunati 60405 has .533/.552 lift with .242 int .252 ext at 50 degrees..and is very streetable and in my duster ran consistent 11.0's...
