Page 2 of 3 1 2 3
Re: 11 seconds with a 416 [Re: rt66jim] #514547
11/06/09 08:10 PM
11/06/09 08:10 PM
Sherman Texas
The Shocker Offline
The Shocker  Offline
Sherman Texas
11.48 with my 408 Dart.
Motor:
.030 over 360 from a 71 pickup ,stroker crank ,eagle rods ,Kieth Black 10 to 1 pistons,Econo W2's Sharp roller rockers,Edelbrock Performer Rpm (wimp)hydraulic cam,Victor intake,750 Demon ,Hedman Fenderwells,MSD ignition.
Trans:
Powerglide ,manual valve body,3000 stall.
Rearend:8 3/4 from the same 71 pickup that the block came from ,with 4.10 gears.
Suspension and tires:
Stock 6 cylinder original springs and torsion bars ,with 15x4 Cragers up front and 15x7 steelies in the back,26x8.5x 15 slicks.
Homeade subframe connectors welded in place .I launch at 2500-2600 and shift at 5800.The car has a best of 11.48 in the 1/4 and 7.27 in the 1/8 and has more in it im sure.You can see in this vid how bad its spinning and costing ET off the line..11's should be easy for your 416 build in a street car...
http://www.youtube.com/watch?v=BIIyWUefEYQ
http://www.youtube.com/watch?v=ykcsXMV3vfg My Dart ,and im just getting started...
Re: 11 seconds with a 416 [Re: The Shocker] #514548
11/09/09 05:52 PM
11/09/09 05:52 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Any other builds?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: 11 seconds with a 416 [Re: 73cuda340] #514549
11/09/09 06:47 PM
11/09/09 06:47 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Just curious why build and spend the extra money for a stroker to go 11's when a good 360 can do it??
Re: 11 seconds with a 416 [Re: 73cuda340] #514550
11/09/09 07:22 PM
11/09/09 07:22 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
11.60 at 116mph w/full exh and 4 mufflers. Street ET tires. 4200lbs with me in it. 360 with 4" Mopar crank. 408 c.i. Home ported junkyard heads. 587 castings. Still has the Leanburn air cleaner on it and cruise control works. Has over 15000 miles on it now and I just added another PRO win in it Saturday night.
Re: 11 seconds with a 416 [Re: MIKES_DUSTER] #514551
11/09/09 07:25 PM
11/09/09 07:25 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
no expert but you can do it with a whole lot less rpm and converter and the motor will live longer and be more fun on the street i gues
Re: 11 seconds with a 416 [Re: qwkmopardan] #514552
11/09/09 07:37 PM
11/09/09 07:37 PM
Phoenix, AZ
Comp_Chassis Offline
Phoenix, AZ
Friend of mine and his brother both have 410 strokers both of fairly similar build.
360 blocks, .040 over, 4" cast cranks, eagle rods, JE reverse dome pistons, 11-1 compression, crane hydraulic roller cams, holley strip dominator intakes. 1 engine has the indy modified edelbrock heads and the other is out of the box indy heads.
The std edelbrock head engine is in a 67 Coronet, 3.55 gears, 727 auto, 3000 converter, full interior, battery still in engine compartment, car can be driven any where any time. Drives it to the track, leaves it in drive and on MT street radials it runs 11.70's.
Other car is a 64 Valiant, 904 trans, full cage, bench seat, mini tubbed, 3.91 gears, MT street radials, drives it to the track and has run 11.00 without really being tuned yet. They just switched it to 3.55 gears and have not run it again yet.
Re: 11 seconds with a 416 [Re: MIKES_DUSTER] #514553
11/09/09 07:38 PM
11/09/09 07:38 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
QUOTE
"Just curious why build and spend the extra money for a stroker to go 11's when a good 360 can do it??"
It only costs a few hundred bucks more to do the 4" crank stroker motor. And the crank is only about $100 more the grinding the 30 year old stock peice. I think it's crazy to not go the stroker route even though I have been 10.20s with a .040 standard stroke 360 at 3100lbs. Now it has run 9.68 at 136 and does this, with a stroker crank 360. Still home ported junkyard heads, 587 castings, .590 flat tappet cam, flat top pistons, and runs on gasoline, 110 octane.
Re: 11 seconds with a 416 [Re: 73cuda340] #514554
11/09/09 10:29 PM
11/09/09 10:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Mines a 408 in a 69 Dart street/strip, 3300#. K-1 steel crank,Comp Star 6.125" H beam rods, Diamond 20 cc dish pistons, ported Edelbrocks, Victor 340, Bigs 950 HP, Hughes flat solid, 260/264 @ .050, .626/.633 lift with 1.6 rockers. With no tuning it ran 6.61 @ 102.24 (1/8) on the only pass I've got it to hook. The compression is only 10.9-1 so I run it on pump 93. It should run mid 10s when it's tuned.
My old hydraulic cammed, pump gas 340 in the same car ran 11.62.
Re: 11 seconds with a 416 [Re: MIKES_DUSTER] #514555
11/09/09 11:19 PM
11/09/09 11:19 PM
clarks summit pa
clarks summit pa
I just figured that it would be cheaper to stroke it than to put even more parts into my 340 to maybe go just as fast. My goal is to atleast hit 11's but Im afraid my 340 will probably only be good for maybe low 13's(build posted earlier in topic). Plus with more cubic inches I have a lot more potential to go even faster.
Re: 11 seconds with a 416 [Re: 73cuda340] #514556
11/10/09 12:02 AM
11/10/09 12:02 AM
Im NOT against a stroker motor but when I think of a stroker motor,I dont think of a 11 second car. I would hope a stroker would go 10's, thats all.
Good luck with your build!!!
Re: 11 seconds with a 416 [Re: MIKES_DUSTER] #514557
11/10/09 01:25 AM
11/10/09 01:25 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
11.0@122 with crappy 1.65 60ft. and only 2 passes
3200lb street duster. power steering,power brakes, full exhaust. Driven daily.
408sb
10.7 compression
indybrock heads
248/577 comp solid roller
victor intake
950 holley
3000 stall
4.10 gears
Re: 11 seconds with a 416 [Re: viperblue72] #514558
11/12/09 09:05 PM
11/12/09 09:05 PM
clarks summit pa
clarks summit pa
Any opinions on cams? Im considering either a comp xe275HL or maybe go to a solid with the Comp XS274.
Re: 11 seconds with a 416 [Re: 73cuda340] #514559
11/13/09 01:23 AM
11/13/09 01:23 AM
V
viperblue72 Offline
viperblue72  Offline
V
Probably not enough cam for what you want to do. You'll need at least another 10 degrees. And don't worry, these sb strokers make plenty of torque down low, even with a bigger cam.
Re: 11 seconds with a 416 [Re: viperblue72] #514560
11/13/09 05:46 PM
11/13/09 05:46 PM
El Dorado Ca
65signet Offline
65signet  Offline
El Dorado Ca
You can find something better than comp, there selection for mopar is not good and most of there cams have to much duration for a good street strip car.
1965 Plymouth Barracuda 273 M/SA
1970 Plymouth Duster 360/904 10.60s with J heads
Re: 11 seconds with a 416 [Re: 73cuda340] #514561
11/13/09 06:27 PM
11/13/09 06:27 PM
Whats the lift on those cams??...when i first built my 416 i was using only a .494/.513 cam and it put my duster in the 11.20's....
Re: 11 seconds with a 416 #514562
11/14/09 12:08 AM
11/14/09 12:08 AM
clarks summit pa
clarks summit pa
Comp XE275HL is 231/237 @ 50 with .525/.525".
Comp XS274 is 236/242 @ 50 with .502/.511".
Re: 11 seconds with a 416 [Re: 73cuda340] #514563
11/14/09 02:27 AM
11/14/09 02:27 AM
Renton Washington
Triple Threat Offline
Renton Washington
Needs bigger cam than those. Look for something in the mid 240's @.050
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: 11 seconds with a 416 [Re: Triple Threat] #514564
11/14/09 05:55 PM
11/14/09 05:55 PM
clarks summit pa
clarks summit pa
How about a 240/246@50 with .507/.510"?
Re: 11 seconds with a 416 [Re: 73cuda340] #514565
11/20/09 06:29 PM
11/20/09 06:29 PM
clarks summit pa
clarks summit pa
Would any of the cams in the 240@50 range still be streetable? I want it to have a nice choppy idle but at the same time I dont want to lose a lot of low end torque.
Re: 11 seconds with a 416 [Re: 73cuda340] #514566
11/20/09 07:15 PM
11/20/09 07:15 PM
The Lunati 60405 has .533/.552 lift with .242 int .252 ext at 50 degrees..and is very streetable and in my duster ran consistent 11.0's...
Page 2 of 3 1 2 3
