Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper
[Re: Joesixpack]
#512638
11/08/13 08:48 PM
11/08/13 08:48 PM
Posts: 11,921 WILKES-BARRE PA
Joesixpack
WILKES-BARRE PA
UPDATE 11/08 trans rebuilt(by Lee Kapustka)supposed to be sunny@59 Saturday....trans going back in...we will try it again!
[Re: Joesixpack]
#512643
11/17/13 08:37 AM
11/17/13 08:37 AM
Posts: 2,212 Minnesota
peabodyracing
Minnesota
Way to go Bill! I can imagine how relieved you must feel.
Lead, follow or get the hell out of the way
[Re: peabodyracing]
#512644
11/17/13 11:11 AM
11/17/13 11:11 AM
Joesixpack
WILKES-BARRE PA
Thanks Larry, Having a second trans built right now as a spare, also bought a third trans as a "test" unit. I enjoy R&R ing them so much!the third unit is a A999 lock up,2.74 first gear,5 clutch drum...once the current combo is "worked in"would like to experiment with the lock up trans. use the 2.74 low gear to launch and get a better 60 foot time, a micro switch on the shifter, when i hit third gear it would lock up...A B-body small block combo is not real common...as time&finances allow would like to try an aluminum driveshaft, an aluminum third member,alloy lite weight axles,aluminum radiator, glass hood&scoop,as i think this is my last project...an aluminum headed 408 would be great for 2015.... https://www.facebook.com/photo.php?v=102...e=2&theater
[Re: Joesixpack]
#512647
03/31/14 01:15 PM
03/31/14 01:15 PM
peabodyracing
Minnesota
Congrats Bill. Looks darn good!
