Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper
[Re: Stroker]
#512622
09/14/13 07:58 PM
09/14/13 07:58 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
well i picked friday the 13th as get some stuff done day.....we bled the brakes, adjusted the shifter, put the hood on, added gas, fired up the engine, 1500 rpm for 12-14 minutes per the builder instructions to break in the cam. engine got to 180,thermostat opened,idled it down, shifted trans into reverse, ok, got reverse, then to "N", ok, into 1st, nothing, 2nd, nothing, 3rd, nothing, no foward gears....full of fluid, have to pull pan, pull valve body and air check some bands and servos...
