Page 3 of 9 1 2 3 4 5 6 7 8 9
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512574
11/13/10 07:15 PM
11/13/10 07:15 PM
Minnesota
peabodyracing Offline
Minnesota
Fantastic Bill! Thanks for the email/pics. Sure glad to see the car going back together so well. We got 5+ inches of snow today. I'm not ready for winter!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: peabodyracing] #512575
05/05/11 05:24 PM
05/05/11 05:24 PM
WILKES-BARRE PA
Joesixpack Offline OP
WILKES-BARRE PA
Finally got back at it this week, got the 3/8s fuel line installed,front brake hoses,dual master cylinder,splitter,lines,steering collumn,headers,starter,seaat belts,rear seat.....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512576
05/05/11 05:25 PM
05/05/11 05:25 PM
WILKES-BARRE PA
WILKES-BARRE PA
Dave working on the 1 3/4 Hooker Super Comps....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512577
05/05/11 05:26 PM
05/05/11 05:26 PM
WILKES-BARRE PA
WILKES-BARRE PA
Got help this week from Don Swanson&Dave a couple of racers from RT66, we got more done this week than i did in months...helps to have extra hands!
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512578
05/06/11 04:42 PM
05/06/11 04:42 PM
WILKES-BARRE PA
WILKES-BARRE PA
5/06 more progress...distributor in,spark plugs in,wiring harness installed,voltage regulator,ballast resistor,oil pressure gauge in,temp sender in,went with Auto Meter electric water temp gauge...no where to plug in my nos moon mechanical water temp gauge...no threaded hole big or deep enough in that manifold...looks like i will mount MSD6C inside under dash,Mount mallory coil to left and below ballast resistor.removed entire heater box assembly, now got two nice holes to run wires thru....have to get some grommets...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512579
05/12/11 07:10 PM
05/12/11 07:10 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Very nice
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Michael] #512580
08/15/11 11:35 AM
08/15/11 11:35 AM
WILKES-BARRE PA
WILKES-BARRE PA
Ok finally back at it....installed battery tray,cables,starter relay,horn relay,coil,MSD6C,ballast resistor,trans cooler lines,seat belts,electric water temp gauge..,horns,electronic ignition wiring harness....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512581
08/15/11 11:39 AM
08/15/11 11:39 AM
WILKES-BARRE PA
WILKES-BARRE PA
powdercoated tray&braces,(Thanks Larry at JIT),nice cad plated mounting bolts(thanks to my friend,the late "Big" Dan Buick)
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512582
08/23/11 04:53 PM
08/23/11 04:53 PM
WILKES-BARRE PA
WILKES-BARRE PA
more progress......carb spacer,carb on,fuel line ran...alternator,brackets,spacers,bolts,pullies,spark plug wires(separators on order)wiring harness to alternator...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512583
08/23/11 04:56 PM
08/23/11 04:56 PM
WILKES-BARRE PA
WILKES-BARRE PA
carpet back in, bench seat in....seat belts.....Dave measuring for Hurst Shifter location....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512584
08/31/11 02:16 PM
08/31/11 02:16 PM
WILKES-BARRE PA
WILKES-BARRE PA
old school radiator repair
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper *DELETED* [Re: Joesixpack] #512585
08/31/11 02:18 PM
08/31/11 02:18 PM
WILKES-BARRE PA
WILKES-BARRE PA
Post deleted by Joesixpack
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512586
09/03/11 09:10 AM
09/03/11 09:10 AM
WILKES-BARRE PA
WILKES-BARRE PA
Thanks to Moparts member STHEMI(Greg),I picked up a radiator and driveshaft,both are now installed....will be firing it up this week and making some noise....got offer from member to drag the beast to INDY for its debut....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512587
03/22/12 08:23 PM
03/22/12 08:23 PM
WILKES-BARRE PA
WILKES-BARRE PA
took driveshaft to machine shop for installing two u joints&spin balancing, suprise,end of shaft where u joint sits is cracked(split)anyway they had a nos 1 left in stock!so he is going to cut the old end off and then remove 1 inch from the shaft to make it easier to instal(was a C-body and about and inch to long)and install&weld the new end cap...put the ujoints in it and drop it into the spin balancer. should be done friday and then i can install the driveshaft,only a few items left to do,hoping to fire it up 3/30 for my birthday present to myself....
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512588
03/23/12 11:13 PM
03/23/12 11:13 PM
WILKES-BARRE PA
WILKES-BARRE PA
end of shaft with nos end cap,installed&balanced
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512589
03/23/12 11:15 PM
03/23/12 11:15 PM
WILKES-BARRE PA
WILKES-BARRE PA
nos slip yolk
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512590
03/23/12 11:16 PM
03/23/12 11:16 PM
WILKES-BARRE PA
WILKES-BARRE PA
balanced rear
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512591
03/23/12 11:19 PM
03/23/12 11:19 PM
WILKES-BARRE PA
WILKES-BARRE PA
quality welds and craftsmanship
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512592
03/23/12 11:22 PM
03/23/12 11:22 PM
WILKES-BARRE PA
WILKES-BARRE PA
3/24 have all day session planned,2 guys coming to help,should get a lot done...
Re: 1966 Belvedere I from S6 Granny Car to 360 Sleeper [Re: Joesixpack] #512593
03/30/12 11:25 PM
03/30/12 11:25 PM
WILKES-BARRE PA
WILKES-BARRE PA
Ok getting closer.....this week the following was done, gear lube in,brake drums on,radiator hoses on,new throttle cable,throttle cable holder,return springs&holder installed,driveshaft in,shifter mounted,cable ran,3/8s union installed in fuel line,hopefully will get time to get trans cooler on,install tach,put in some gas,trans fluid,top off radiator,and drop in a battery....and fire it up....run it,go thru gears,check for leaks,tighten everything up,break engine in....get header mufflers adapters and bolt on the screaming purple hornies..
