Six Pack air cleaners? #511668
10/30/09 04:18 PM
10/30/09 04:18 PM
Northern VA
1970440six Offline OP
Northern VA
I have a 1970 RR 440 Six pack with airgrabber hood. What is the correct Air cleaner assembly for this model. I have seen many different ones, the one I currently have which I beleive to be the original does not have any numbers stamped on it???
How many different air cleaner assemblies were made for six pack cars?
Re: Six Pack air cleaners? [Re: 1970440six] #511669
10/30/09 05:38 PM
10/30/09 05:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
3 were made , one for 69.5 A 12 cars , one for the T/A and AAR's and one for all the rest, the std oval unit is the one you want , it's probably what you have .
Re: Six Pack air cleaners? [Re: JohnRR] #511670
10/30/09 06:23 PM
10/30/09 06:23 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Additionally a shaker six pack was offered and a non air grabber car had a shield in the front to protect fronm gunk.
Re: Six Pack air cleaners? [Re: 1970440six] #511671
10/31/09 01:51 AM
10/31/09 01:51 AM
Shoreline, Washington
72roadrunnergtx Offline
1970 six-pack b-body? Pretty sure only two bases available, with and without N96. Without “fresh air” hood the base has a splash shield across the front.
with N96 (Air Grabber) will have this base
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
Re: Six Pack air cleaners? [Re: moparpollack] #511672
10/31/09 04:11 PM
10/31/09 04:11 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
doooh .... i forgot about the ebody shaker hood
Re: Six Pack air cleaners? [Re: JohnRR] #511673
10/31/09 08:26 PM
10/31/09 08:26 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
Re: Six Pack air cleaners? [Re: Day2Runner] #511674
10/31/09 08:35 PM
10/31/09 08:35 PM
Fort Workin Tx
Day2Runner Offline
Day2Runner  Offline
Fort Workin Tx
A12 style
note the tubes that the carb studs comes thru
ok experts whats this for ??
none of the other had this
im thinking to run without lid and filter
Re: Six Pack air cleaners? [Re: Day2Runner] #511675
10/31/09 08:52 PM
10/31/09 08:52 PM
colorado
a12superbee Offline
a12superbee  Offline
colorado
Even with the picture blown up I don't see anything different from a normal a12 base.
I can't afford this. mark
Re: Six Pack air cleaners? [Re: 1970440six] #511676
10/31/09 09:08 PM
10/31/09 09:08 PM
USA
b54406barrel Offline
USA
A few N96 cars had the air cleaner with the shield, such as this Dec. '69 Motor Trend road test car and also mine came with the shielded one. Most ag's didn't have the shield though from what I've been able to tell.
Re: Six Pack air cleaners? [Re: b54406barrel] #511677
11/01/09 01:22 PM
11/01/09 01:22 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Do you have a picture of your car with the hood closed but the scoop open where you can see the air cleaner?
Re: Six Pack air cleaners? [Re: NicksGarage] #511678
11/01/09 03:51 PM
11/01/09 03:51 PM
USA
USA
I didn't until about a 1/2 hour ago.
Re: Six Pack air cleaners? [Re: b54406barrel] #511679
11/01/09 07:56 PM
11/01/09 07:56 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Cool. Could I use those pictures on my air cleaner identification page?
Doesn't look like the splash shield would really make much of a difference in that setup since rain would shoot right over it.
Re: Six Pack air cleaners? [Re: NicksGarage] #511680
11/01/09 11:30 PM
11/01/09 11:30 PM
USA
USA
Sure, no problem. I tried to attach the pic to a PM to you but it didn't work so I've attached it here.
No, it wouldn't help with rain much but it also really doesn't block the ag all that badly. I have always wondered if it was a requirement on CA state sold cars as part of the required noise reduction package. That motor trend tested, 6bbl runner had a CA dealer plate on it.
Re: Six Pack air cleaners? [Re: b54406barrel] #511681
11/06/09 03:52 PM
11/06/09 03:52 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I believe the "California Noise Reduction" AirGrabber/Ramcharger HEMI & 6bbl cars used the air cleaners WITH the shield.
Re: Six Pack air cleaners? [Re: 6bblgt] #511682
11/06/09 04:43 PM
11/06/09 04:43 PM
Ramona, CA
NicksGarage Offline
NicksGarage  Offline
Ramona, CA
Do you have anything to back that up?
Re: Six Pack air cleaners? [Re: 6bblgt] #2585244
11/30/18 04:20 PM
11/30/18 04:20 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
my neighbor is orig owner 70 440-6 roadrunner..has the shield factory N96 car.. don't recall if its a noise reduction car [it has tips] he bought it in washington state.. will look close next time i see it..
Re: Six Pack air cleaners? [Re: JohnRR] #2585298
11/30/18 06:47 PM
11/30/18 06:47 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Additionally a shaker six pack was offered and a non air grabber car had a shield in the front to protect fronm gunk. <img src="/ubbthreads/images/graemlins/apimp.gif" alt="" />
doooh .... i forgot about the ebody shaker hood <img src="/ubbthreads/images/graemlins/spank.gif" alt="" />
Nobody cares about the E body !!!!!!!!!! rolleyes
Re: Six Pack air cleaners? [Re: 62maxwgn] #2585361
11/30/18 09:17 PM
11/30/18 09:17 PM
Mechanicsburg, PA
LemonTwiist Offline
LemonTwiist  Offline
Mechanicsburg, PA
This air clear is original to the car
Re: Six Pack air cleaners? [Re: NicksGarage] #2585423
11/30/18 11:05 PM
11/30/18 11:05 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
I believe what Dan said is correct.
Out here we had one of the four 70 Coronet R/T 426 Hemi 4 speeds, F8 green with 14" steel wheels. I looked at it before it was restored and this is the air cleaner on the car, with the shield.
