67 coronet and 67 gtx wheel lip moldings #509637
10/28/09 03:34 AM
10/28/09 03:34 AM
mass
0
03dodgeram Offline OP
mass
are the wheel lip moldings the same for a 66 67 coronet 500 to a 66 67 gtx satillite.thanks
Re: 67 coronet and 67 gtx wheel lip moldings [Re: 03dodgeram] #509638
10/28/09 08:19 AM
10/28/09 08:19 AM
Northern Indiana
mr_belvedere Offline
super gas
super gas
Northern Indiana
No, quite different.
Re: 67 coronet and 67 gtx wheel lip moldings [Re: 03dodgeram] #509639
10/28/09 08:23 AM
10/28/09 08:23 AM
Pendleton NY
terzmo Offline
terzmo  Offline
Pendleton NY
Satellites are connected to side molding that go down entire side of car...GTX only are wheel opening trim
Re: 67 coronet and 67 gtx wheel lip moldings [Re: terzmo] #509640
10/28/09 02:20 PM
10/28/09 02:20 PM
Northern Indiana
super gas
super gas
Northern Indiana
, but only for 1967. 1966 Sat wom is nearly identical to 67 GTX with the exception that the trailing edge of the fronts are stamped to facilitate fitting over the rocker molding, the rears have an area on the leading and trailing ends for the same purpose.
Re: 67 coronet and 67 gtx wheel lip moldings [Re: mr_belvedere] #509641
10/28/09 02:29 PM
10/28/09 02:29 PM
Northern Indiana
super gas
super gas
Northern Indiana
...also, the 1967 Coronet 500 wom are shorter as they connect to side trim along the lower style line, similar to the 67 Sat. No too familiar with the 66 Coronet 500 wom.
Anyway, the top of the front wheel opening is somewhat flat on the 66-7 Dodge b-body where the 66-7 Plymouth is more rounded. The molding profile is much different between the Dodge and Plymouth also.
Re: 67 coronet and 67 gtx wheel lip moldings [Re: mr_belvedere] #509642
10/28/09 02:59 PM
10/28/09 02:59 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
67 GTX and 67 Belvedere II share the same WO moldings. 67 Satellite are unique as mentioned above.
Re: 67 coronet and 67 gtx wheel lip moldings [Re: ScottSmith_Harms] #509643
10/28/09 05:26 PM
10/28/09 05:26 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Also 66 Sat has Black paint in the grooves.
