Re: Ok whats the deal on all these nascar,P/S truck mot [Re: cheapstreetdustr] #509380
10/28/09 01:01 PM
10/28/09 01:01 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
The mid plate will accept SB bell. The R5 engine does not have the stock mopar bell pattern.
The crank spacer will work for fly wheel or flex plate. I made my spacer with the chevy bolt pattern, then used the spacer as a fixture to drill the flywheel...
These engine are right around 12:1 from the shops, probably not a good idea to boost them the way they are....
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Ok whats the deal on all these nascar,P/S truck mot [Re: DemonDust] #509381
10/28/09 08:04 PM
10/28/09 08:04 PM
Akron, Ohio
ProSport Online content
ProSport  Online Content
Akron, Ohio
So they require straight race gas and a front steer conver$ion, ok I'm out.
Re: Ok whats the deal on all these nascar,P/S truck mot [Re: ProSport] #509382
10/28/09 08:12 PM
10/28/09 08:12 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
E-85.... E-85.... E-85....E-85
SDG Motorsports
Re: Ok whats the deal on all these nascar,P/S truck mot [Re: DemonDust] #509383
10/28/09 08:30 PM
10/28/09 08:30 PM
Big Island ,VA
JC Childress Offline
Big Island ,VA
They dont have to be a front steer .I know this for a fact. We bought three of these engines from Chip Ganassi. We put one in a Duster. We had a chassis shop relocate the factory steering box rearward a bit and he re-fabbed the drag-link and whatnot to make it work, but it does not have a rack and pinion. It has the factory steering box and it all cleared fine,although, it may possibly be cheaper to put a rack and pinion in.
These are neat engines and we make adapters where I work as well. We have even sold one to a Moparts member !
J.C. Childress (434) 665-9541
Re: Ok whats the deal on all these nascar,P/S truck mot [Re: JC Childress] #509384
10/28/09 08:36 PM
10/28/09 08:36 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
Do you have any pics of the car?
You must have had to chop the K frame though, when I set my R5 in there was no way it was gonna sit down far enough without removing the some of the K frame or moving the engine way back...
SDG Motorsports
Re: Ok whats the deal on all these nascar,P/S truck mot [Re: DemonDust] #509385
10/29/09 03:13 PM
10/29/09 03:13 PM
acworth / N. georgia - south e...
cheapstreetdustr Offline OP
this was gonna be my next question..will it fit with a modified k member..?
i figured there would be more room being a dry sump?
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Ok whats the deal on all these nascar,P/S truck mot [Re: cheapstreetdustr] #509386
10/29/09 03:27 PM
10/29/09 03:27 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
If your going to do it do it right the frist time hole lot less money install aftermarket K member you wont be sorry buy the time you hope to make it work right and it does not you will have wasted a lot of time and money dont ask me how i know I just know
Re: Ok whats the deal on all these nascar,P/S truck mot [Re: scottb] #509387
10/29/09 03:41 PM
10/29/09 03:41 PM
Big Island ,VA
Big Island ,VA
It can be done "RIGHT " by trimming the factory k-member a good bit and moving the steering box rearward ( and a few other things...I cant say exactly because I dont know exactly...I'm not a chassis man ).
Of course the aftermarket k-member would be super nice as well. Kinda like baking cakes....lots of different recipes and lots of good cakes !
Re: Ok whats the deal on all these nascar,P/S truck motors? [Re: cheapstreetdustr] #509388
10/29/09 06:13 PM
10/29/09 06:13 PM
AndyF Online content
AndyF  Online Content
Rather than a $3K suspension why not just spend $800 on a custom dry sump oil pan that clears the tie rod? I'm sure that Charlie can weld up a pan that fits the rear steer suspension and still has the pickups in an okay place.
