Power steering pump on a 73 440? #508658
10/27/09 10:26 AM
10/27/09 10:26 AM
N.E.Ohio
P
Polarabill Offline OP
P
N.E.Ohio
I have a 73 440 in my 64 polara. The car is equiped with power steering but when I bought the motor it didn't have the pump or brackets needed for the pump. I riggged up a unit from a 60's truck but it has given me problems since day one. It has developed a major leak and I want to put something closer to original on it.Can any one show me pictures of what I need or supply part numbers? Thanks.
This would be so much easier if I knew what I was doing...
Re: Power steering pump on a 73 440? [Re: Polarabill] #508659
10/27/09 11:28 AM
10/27/09 11:28 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Not a real good one but its a start. Its the best I have.
Re: Power steering pump on a 73 440? [Re: Polarabill] #508660
10/27/09 03:10 PM
10/27/09 03:10 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I can show you a pic of mine when I get home tonight, mine's a 76 440. Mine's got the federal pump on it. If you're putting together a pump from scratch I recommend you go with the saginaw pump instead. Just so much easier to find parts(brackets, hoses, pumps, pump caps, etc) for the saginaw setups than the federals.
Re: Power steering pump on a 73 440? [Re: Polarabill] #508661
10/28/09 09:22 AM
10/28/09 09:22 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Hopefully my setup will help you:
Re: Power steering pump on a 73 440? [Re: Commando1] #508662
10/28/09 09:55 AM
10/28/09 09:55 AM
N.E.Ohio
P
P
N.E.Ohio
Thanks, those pics will give me an idea on what to look for.
Re: Power steering pump on a 73 440? [Re: Polarabill] #508663
10/28/09 12:42 PM
10/28/09 12:42 PM
florida
74fldart Offline
74fldart  Offline
florida
here is a higher mount set up, go to 440source.com for brackets.
Re: Power steering pump on a 73 440? [Re: 74fldart] #508664
10/31/09 12:03 AM
10/31/09 12:03 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
Those are federal pumnps... saginaw brackets are diff but fits on same places at block/water pump housing.
The higher mounting kind is for cars with water pump inlet on driver side ( pre 72 )
