Re: old school crazy paint jobs
[Re: Dyno1]
#50766
12/26/07 01:53 AM
12/26/07 01:53 AM
Posts: 9,108 Rogue River, OR
Jeremiah
Rogue River, OR
Local Original Hemi car, out in the light for the 1st time in many years.
Is that Steve Lisk's old car??? ![](/ubbthreads/images/graemlins/shock.gif)
Ooops...edit I just remembered that it was a Challenger...
[Re: Jeremiah]
#50767
12/26/07 10:55 AM
12/26/07 10:55 AM
Posts: 16,619 Almost Heaven
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
Some of those cars (Vanke, Myl) were painted by the same guy - Greg of Akron. Pic courtesy of Steve Stasko (as far as I can tell ![](/ubbthreads/images/graemlins/smile.gif) )
Everybody makes fun of a hillbilly until they need something fixed
[Re: B_Body_Bob]
#50768
12/26/07 10:56 AM
12/26/07 10:56 AM
B_Body_Bob
Master of nothing
Master of nothing
Almost Heaven
This is another Greg painted car out of the Akron area - Kid Presto.
Pic courtesy Stewart Pomeroy
[Re: Mopar_Rich]
#50771
12/26/07 01:09 PM
12/26/07 01:09 PM
Posts: 6,257 acworth / N. georgia - south e...
cheapstreetdustr
Yowell alsway had neat paint..and alot of them.. must have painted his cars twice a yr..lol some of the names ive collected are Kar Kolors Del-star Circus circus Vaniderstine Show Cars Bruce the brush etc.. cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured [image][/image]
[Re: cheapstreetdustr]
#50772
12/26/07 01:18 PM
12/26/07 01:18 PM
cheapstreetdustr
this and some larger scallops would be killer on a cuda.. to get the 3d correct do the lighter base color then the darker color fades over the templates..to get the right dimension. then use a "hole" template to add the ligher fades like blue,purple,gold or silver..to get a real fish scale effect.. its not that hard..just a steady hand and patience you have to have dry panels when blowing over with the circle "hole" templates. and it doesnt take much paint..just light dustings. Ive never been to Texas? ? well san antonio once. cheapst.
[Re: GTSDave]
#50779
12/26/07 01:34 PM
12/26/07 01:34 PM
cheapstreetdustr
no..PPG base clear.. it started out i removed the vynl top because i thought i had rust under it.. i didnt but after removing the top ..i had my paint supply color mix me some paint to finish the top and i was gonna blend it at the b pillars. but the first application(mix) was much lighter. so the second color was pretty much spot on.. but since the roof was already shot in the lighter green i went and did the scales with the darker matching body color..i was thinking it might be hard to blend new color to the old on the b pillar. but with the scales ending..i could camoflauge it. i ended up sanding and painting most all of the car ..except the hood...(i planned on a glass hood) i would do a base color-main body color first.. then do the graphics ontop of that.. either of these could be auto air..? but auto air could also be applied for the graphics over the conventional base paint.. ive never had an issue..except the base color if its solvent base may need to be cleared in a timely/window.. the auto air doesnt have to be..FWIW cheapst.
#50781
12/26/07 01:44 PM
12/26/07 01:44 PM
cheapstreetdustr
this is the hemi car with the same effects..only in a different color. i hadnt seen this car until after i already did mine. it looks like its the same technique though.
#50782
12/26/07 01:44 PM
12/26/07 01:44 PM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
Thanks,
I believe I will go with a black base, and come back with candy gold, then come in with the graphics in green and gold pearls. Gonna order up some candy concentrate to play with it a bit and see how it comes out.
I have had great luck with some of the Alsa Corp Mirror Chrome, and may use some of that under the gold candy. Should give it a gold mirror effect, coupled with the scales. Should be fun to play with at least hehehehe.
-Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: GTSDave]
#50783
12/26/07 01:53 PM
12/26/07 01:53 PM
cheapstreetdustr
ive used some of the Chrome or silver plating machines to try to chrome plastic..or look like chrome.. havent tried the Asla painted chrome...but iam very familiar with their products the helmet i showed was silver plated first FWIW cheapst
