Do you think this cam is to big? #507425
10/25/09 09:33 PM
10/25/09 09:33 PM
Spokane Valley WA
dan6412 Offline OP
dan6412  Offline OP
Spokane Valley WA
My son and I are doing a 383 budget build for his Superbee. This is what we are working with. 69 383 HP stock bottom end (very good running just pulled from a charger 3 months ago) 906 heads w/about 5000 miles on them. We are going to run a set of Hooker header, weild intake and 650 carb. My question is I have a new in the box Mopar performance cam that is a 509 lift at 292 duration do you think this is to big of cam for what we have. If not will the stock springs work? Also the car is a 4 speed.
Re: Do you think this cam is to big? [Re: dan6412] #507426
10/25/09 09:41 PM
10/25/09 09:41 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Way too much cam for stock 383 even with the stick. And no the stock springs wouldn't work anyway
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Do you think this cam is to big? [Re: dan6412] #507427
10/25/09 10:04 PM
10/25/09 10:04 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
In general, I agree with that.
It's gonna be a pig.
BUT if you have your heart set on it,springs will need replaceing, perhaps the guides cut down for retainer clearance, and a bunch of gear(391's or better).
Even an hp 383 won't be 10:1 comp in real life (the pistons would have to be domed for that with 906's) so depending what your goals are, you are likely better with something a lot less
Re: Do you think this cam is to big? [Re: dave571] #507428
10/25/09 10:16 PM
10/25/09 10:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
No matter how tight the budget is, DO NOT put that cam in it. That cam is designed for everything you don't have : high compression, high stall(edit, realized your was a 4-speed but I still don't think that would help enough to make me want to run this cam in your 383), numerically high rear gears, and a full 440 cubes would help.
If the budget is that tight, I would rather run the stock cam. If you still want an aftermarket cam but don't want to spend $$$, I'd look at the summit cam/lifter kits. The small summit kit K6400 is roughly equivalent to the stock 440-hp cam. And it should work fine with your current springs.
Re: Do you think this cam is to big? [Re: DaytonaTurbo] #507429
10/25/09 10:41 PM
10/25/09 10:41 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
Even the .484 cam is HUGE in a stock 383... (I tried it)FWIW I'd sell that .509.. For some reason people still go for the old MP grinds and they resell pretty easy! Or do some horse trading for something better suited... Voodoo 60301 or the mentioned Summit cam both should get by with your springs
Re: Do you think this cam is to big? [Re: R70RUNNER] #507430
10/26/09 12:13 AM
10/26/09 12:13 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
I put that cam in a stock 440... it sounded great!
but it was a total slug to drive..everyday performance was BAD..NO fun
I changed to a .471 Street hemi style grind and it woke right up, a really good choice for a stock motor.
Re: Do you think this cam is to big? [Re: sthemi] #507431
10/26/09 12:23 AM
10/26/09 12:23 AM
Spokane Valley WA
dan6412 Offline OP
dan6412  Offline OP
Spokane Valley WA
Thanks every one thats what I was thinking it was a little on the over kill side. I got it in a parts deal. So up for sale she goes. We will stick with the Crane thats in it now like I said it ran very well as it was.
Thanks again.
Re: Do you think this cam is to big? [Re: dan6412] #507432
10/26/09 10:03 AM
10/26/09 10:03 AM
Grand Haven, MI
patrick Offline
patrick  Offline
Grand Haven, MI
if you're looking for a good cam that will be a power upgrade from the cam that's in there now, I'd use a lunati voodoo 60302 with comp 911 springs.
2017 Grand Cherokee Overland
Re: Do you think this cam is to big? [Re: patrick] #507433
10/26/09 10:31 AM
10/26/09 10:31 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I would run it all it needs is a little cam advance and it will kick ##$. you should upgrade the springs to 33's or some comp cams ones
http://chucker54.stores.yahoo.net/valvesprings2.html
The 509 is a great cam and in a four speed it will be fine. Most inexperienced posters don't know how to set them up. They are best with mild no brainer cams. Hey if it don't work installed as I say it's and easy enough out!!! (but it will work)So Install it with the intake centerline (max lift) at least 4 advanced in at 102 or maybe even 100 and it will have all the life and pop you want!
I personally love this cam for the street and light strip. But unlike most above I like all the power you can get and have learned over the years how to make bigger cams work to get low end and max power!!
Re: Do you think this cam is to big? [Re: Dodgem] #507434
10/26/09 05:44 PM
10/26/09 05:44 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
The 509 is a bad choise all around for a stock motor. Don't care how far you set in advance. Why to much cam for no comp and no gear. Go with the stock hemi grind or lunarti 302. you'll be happy. Sell that 509.
Re: Do you think this cam is to big? [Re: Dougsmopars] #507435
10/26/09 06:17 PM
10/26/09 06:17 PM
rochester,new york
P
plumebody Offline
plumebody  Offline
P
rochester,new york
I actually had good luck with the old 509er. 383 9:1,duel plane,3.91's 2800 stall. 12.50's in a challenger.
Re: Do you think this cam is to big? [Re: plumebody] #507436
10/26/09 09:08 PM
10/26/09 09:08 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
Although "too big" does seem to mean different things to different people, I ran a .484 in a basically stock '69 383, A-body, 4-speed, 3.23 rear and it was a blast on the street.
Also the original Direct Connection "Engine" book mentions running the .509 in a Duster with an 8.5:1 400 and it was pretty quick (mid 11's?) been a long time since I read through that book though.
Re: Do you think this cam is to big? [Re: Dodgem] #507437
10/26/09 09:09 PM
10/26/09 09:09 PM
South Jersey
kruger Offline
Yours Too!
kruger  Offline
Yours Too!
South Jersey
I agree.Some guys put there cams in per card specs and wonder why there speedboat launchs like a tugboat.When Mopar Performance test there Purple Shaft cams they advance them 2dg's and list them as such(Mopar Engines 8th Edition).But not that way on there cam cards.
If you do decide to try the 509,get some springs and 391's and check the piston to valve clearence after you adavance it.4 speeds need alittle more VP clearence
Edit:Uuuum you have the lifters to that cam too? Shoot me a pm after you decide
Re: Do you think this cam is to big? [Re: kruger] #507438
10/26/09 10:13 PM
10/26/09 10:13 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
The .509 makes power. But the wrong type for a street car. Assuming the poster who disagree are ignorant shows a heck of a labido. I've run the .509, and I've taken them out when they are all wrong. For the poster's need it's wrong. There are MUCH better cams out there, and even if you do want to run 70s technology the 21st century low bidder manufacturing stinks on them. Do yourself a favor and have the block blueprinted and run something designed for modern all around performance. In any case, replace the springs to match your cam choice. Stock springs are too weak for any perfomance cam worth buying.
Re: Do you think this cam is to big? [Re: moper] #507439
10/26/09 10:31 PM
10/26/09 10:31 PM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
I didn't even bother to respond to the other reply.. . why start a I have neither the interest or time for it My only comment will be figure out the dynamic compression on that 383 with that cam...And the OP hasn't even offered the gearing in the car yet.
Agreed the 02 voodoo would be a very good choice and was my initial thought, but still trying to keep in the guidelines set by the OP (his current springs.) I went more conservative
Re: Do you think this cam is to big? [Re: R70RUNNER] #507440
10/27/09 08:02 AM
10/27/09 08:02 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
If you have a 3.91 or steeper gear, and want to switch to a single plane intake, and shave the heads for more compression, swap in the correct valve springs, and add 750 double pumper...it will work fine and should run in the 12's depending on your shifting. If you would prefer to keep everything you have the same, I would not go bigger than say the hemi grind.
2 kids and a dog
Re: Do you think this cam is to big? [Re: TonyS451] #507441
10/27/09 10:25 AM
10/27/09 10:25 AM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
The .509, i personally like this cam, works really good for a bracket cam for its low price, they are also nice for a street car, but only if you don't mind building the engine/drivetrain around it to get the full potential out of it, for such a small lift, they are very aggressive with lots of overlap & dur. & .50", but not really a good choice for the adverage street cruiser with a mild combo, your overall combo on the car is conservitive, so stay conservative on the cam, you'll be much happier.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
