Tree sap removal ? #503826
10/22/09 02:06 PM
10/22/09 02:06 PM
Bloomington, Illernoise
cptn60 Offline OP
cptn60  Offline OP
Just bought a 96 LHS; nice car unfortunately previous owner parked beneath a tree and car is just covered with sap. Already tried Acrysol and some mild detergent but it's pretty stubborn. Anyone have any ideas? I can chip it off with my fingernail, but it's not a Colt-sized vehicle. Like to try something that won't tear the clearcoat up.
This space available for rent
Re: Tree sap removal ? [Re: cptn60] #503827
10/22/09 02:08 PM
10/22/09 02:08 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
goof off? Sticker remover? WD-40?
Coming soon!!!!
Re: Tree sap removal ? [Re: Mr.Yuck] #503828
10/22/09 02:11 PM
10/22/09 02:11 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Try Gunk engine degreaser (white can w/orange lid).
Re: Tree sap removal ? [Re: Neil] #503829
10/22/09 02:13 PM
10/22/09 02:13 PM
USA
b54406barrel Offline
USA
Really-really hot (wear rubber gloves) water with with lots of detergent has always worked for me.
Re: Tree sap removal ? [Re: b54406barrel] #503830
10/22/09 02:16 PM
10/22/09 02:16 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Hot soapy water and a wash mitt. Wax afterward.
logan426
Re: Tree sap removal ? [Re: cptn60] #503831
10/22/09 02:24 PM
10/22/09 02:24 PM
Jacksonville Florida
elitecustombody Offline
soft cloth damp with lacquer thinner,nail polish remover,usually comes off in one or two wipes,do not scrub or use pressure,wax after getting the sap off
Re: Tree sap removal ? [Re: elitecustombody] #503832
10/22/09 02:29 PM
10/22/09 02:29 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I should also mention that engine degreaser works great for taking off road tar too.
Re: Tree sap removal ? [Re: Neil] #503833
10/22/09 02:32 PM
10/22/09 02:32 PM
USA
USA
bbq starter fluid works great, too!
Re: Tree sap removal ? [Re: b54406barrel] #503834
10/22/09 03:00 PM
10/22/09 03:00 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Still,you are better off using hot soapy water,no chance what so ever of any paint damage.
Re: Tree sap removal ? [Re: cptn60] #503835
10/22/09 06:32 PM
10/22/09 06:32 PM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
I use 3M adhesive remover.
Ride eternal, shiny and chrome
Re: Tree sap removal ? [Re: cptn60] #503836
10/22/09 07:15 PM
10/22/09 07:15 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
Soak a couple of them with a good penetrating oil (not WD40) for an hour. If they don't soften up it's going to be tough. Around here the sap leaking trees are acidic and even if you get the sap off it's already too late after 24 hours. The sap penetrates into the clear coat and ruins the paint under the drip.
Re: Tree sap removal ? [Re: cptn60] #503837
10/22/09 07:21 PM
10/22/09 07:21 PM
Arizona
az426john Offline
az426john  Offline
Arizona
I have had good luck with both WD-40 and kerosene.
Naphtha might also work, but you would want to test it on an inconspicuous painted area first.
Re: Tree sap removal ? [Re: az426john] #503838
10/22/09 09:10 PM
10/22/09 09:10 PM
still waiting on 684
K
Kiner Offline
Kiner  Offline
K
dupont Bug and tar remover.
In the black and white bottle.
I used prepsol once.
Re: Tree sap removal ? [Re: 62maxwgn] #503839
10/22/09 09:25 PM
10/22/09 09:25 PM
lacquer thinner,acetone,nail polish remover,mineral spirits,gasoline,kerosene,reducer will work just fine ,common sense helps not to cause any damage to the paint,
avoid scrubbing,scratching or applying pressure,never use scotch pad,nails,razors,putty knife,e.t.c. unless you're planning to repaint
Re: Tree sap removal ? [Re: elitecustombody] #503840
10/22/09 10:30 PM
10/22/09 10:30 PM
Russiaville, IN
mopar376d Offline
mopar376d  Offline
Russiaville, IN
Goof Off or Goo Be Gone
Great stuff.
I used it to get road paint lines off my truck. Buffed and waxed after I was done. Looked like new.
Why does divorce cost so much? Because it is worth it!!!!!
Re: Tree sap removal ? [Re: mopar376d] #503841
10/22/09 10:52 PM
10/22/09 10:52 PM
Clinton Twp. Michigan
coronet1966d Offline
clay bar?
Re: Tree sap removal ? [Re: cptn60] #503842
10/22/09 10:53 PM
10/22/09 10:53 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
have very good resualts with starting fluid .
dries fast enough to not hurt paint and goo is gone .
Re: Tree sap removal ? [Re: calrobb2000] #503843
10/24/09 12:53 PM
10/24/09 12:53 PM
Davenport, IA
70shaker Offline
70shaker  Offline
Davenport, IA
Rubbing alchohol has worked for me and does not hurt the paint althouh it will take the wax off.
Ex Hemi Racer
70 Challenger Hemi 4 speed clone
