DANA Problem ***UPDATE***
#501893
10/20/09 08:25 AM
10/20/09 08:25 AM
Posts: 803 Fl. USA
PS Arrow
Fl. USA
I had the Arrow up on stands, working on the wheelie bars and I noticed the left tire could be moved in and out...The axle is sliding inside of the bearing. The only thing that stopped the axle from coming out was the pressed on retainer. Gear oil was also leaking, don't know yet if it was coming from between the axle and the bearing or through the bearing. BTW these are Strange axles.
I am heading to ART for some bearings this morning, I need to press the locking collar and remove the bearing and measure the axle, I am hoping that it's just a bad bearing and did not wear the axle. I'm guessing both are pretty hard material and not sure which would wear first to the point that the bearing has lost press. I pulled the right side, and the collar was about 3/4" away from the bearing but the axle is not sliding on the inside the bearing like the left side.
Should I tack the collar to the axle? I really don't want this to happen again, but I also don't want to compromise the integrity of the axle by welding on it. I was going to tack it with a Tig to hopefully only have localized heating.
Anybody seen this before?? Thanks, John
Re: DANA Problem
[Re: PS Arrow]
#501894
10/20/09 09:42 AM
10/20/09 09:42 AM
Posts: 3,300 Northern Indiana
Dunnuck Racing
Northern Indiana
I had the same thing happen on an 8 3/4 years ago.It had the Green bearings and Strange axles. Mine ended up being a lock collar that was bad or defective.I put the new on with red Loctite and never had another problem There is no way I would weld on an axle,Loctite might not be the proper way,but it worked for me.
Re: DANA Problem
[Re: B G Racing]
#501898
10/20/09 12:41 PM
10/20/09 12:41 PM
Posts: 803 Fl. USA
PS Arrow
Fl. USA
Press collar on correctly and use sleeve or retainer seal from Permatex.Some times the axle flange bearing seat area is too deep and needs a shim to keep the axle from moving in and out, check that also.
Thank You Again!!!
Post deleted by Defbob
[Re: Ramcharger]
#501900
10/20/09 03:17 PM
10/20/09 03:17 PM
Re: DANA Problem
[Re: B G Racing]
#501901
10/20/09 03:49 PM
10/20/09 03:49 PM
Posts: 184 Central Coast
Plumcrazyracing
Central Coast
I have a strange ultimate 60 and the bearing seat area on their axle housing ends are too deep! I called and asked for their specs and their specs are too deep for use with the green bearing with retainer plate. I had to machine spacers to fit between the green bearing and the bearing seat area. I used remnants from an old DANA housing axle tube!
Re: DANA Problem
[Re: Plumcrazyracing]
#501902
10/20/09 04:29 PM
10/20/09 04:29 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
We usually make a aluminum spacer.Most axle manufactures do not recommmend weld of any kind on the axle shaft.
[Re: RussW]
#501905
10/20/09 09:13 PM
10/20/09 09:13 PM
Re: DANA Problem
#501907
10/20/09 11:33 PM
10/20/09 11:33 PM
the bearings on my Duster are tacked
The spider gears are probily welded too.
Re: DANA Problem
#501909
10/21/09 02:26 AM
10/21/09 02:26 AM
Posts: 803 Fl. USA
PS Arrow
Fl. USA
I had a problem with the collars not staying in place on my Strange axles. I had a shop tack weld them, problem solved.
Dave, were you running a spool in the Duster?
Re: DANA Problem
[Re: RussW]
#501910
10/21/09 02:26 AM
10/21/09 02:26 AM
Posts: 803 Fl. USA
PS Arrow
Fl. USA
The Green Bearing Saga continues
I was not aware that there was a green bearing saga..
