Rear end upgrades? #500578
10/18/09 09:17 PM
10/18/09 09:17 PM
Lemont, IL
Not_A_Blazer Offline OP
super gas
super gas
Lemont, IL
Has anyone here swapped a newer rear axle into their early 50's Mopar? I've heard Jeep cherokee rears are the right size,as well as e-body rears. Also one guy told me he swapped a f-body rear into a 50 plymouth,but the overall width was too narrow,and he had to run wider rear wheels.
Re: Rear end upgrades? [Re: Not_A_Blazer] #500579
10/18/09 10:09 PM
10/18/09 10:09 PM
Tracy CA
rabid scott Offline
"You're Where?"
rabid scott  Offline
"You're Where?"
Tracy CA
I put a '69 Fury III rearend into a 1952 Plymouth Business Coupe, worked fine for me.
Re: Rear end upgrades? [Re: rabid scott] #500580
10/19/09 12:16 PM
10/19/09 12:16 PM
Chino Valley
RodStRace Offline
RodStRace  Offline
Chino Valley
Re: Rear end upgrades? [Re: RodStRace] #500581
10/21/09 02:39 AM
10/21/09 02:39 AM
Cooperstown, NY
jrlegacy23 Offline
jrlegacy23  Offline
Cooperstown, NY
E-Body and most C-Bodies use the same width rears, so they are readily available. there is about 1/8th difference in width between the two.
[color:"#00FF00"]68 Fastback Barracuda with some stuff[/color]
