727 first/reverse band ?
#499824
10/17/09 08:21 PM
10/17/09 08:21 PM
Posts: 289 Lowes
steve660
Lowes
How critical is first/reverse band adjustment on a 727 when using a manual valve body, bolt in sprag, and no transbrake?? Was told the band was only used as a backup/safety when running bolt in sprag. What would happen if band was too loose? Car runs low 10's on motor.
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure. ..... Now its a door stop....
