Early hemi? #499058
10/16/09 08:50 PM
10/16/09 08:50 PM
Vandergrift,PA
The70RTChallenge Offline OP
Vandergrift,PA
I am in dire need of GOOD information about the C.I # and year my hemi has been made. All i know is it came out of an old truck, it has no water ports in the fronts of the heads, doesn't have the built in bell housing(so not a 331), has dual single barrel holley "Governor" Set up, I took off the intake manifold assembly and the val. pan and found no numbers except a few on the back of the timing chain cover that disapear into the seam. I also found a W3 inside the block under val. pan. Any good free information you have, please help me out! thanks
Re: Early hemi? [Re: The70RTChallenge] #499059
10/16/09 09:08 PM
10/16/09 09:08 PM
dark side of the moon
Dougsmopars Offline
Dougsmopars  Offline
There should be a number stamped in front of valley cover on top rail of block right behind water pump. If it's an industrial motor there should be a tag riveted somewhere on side of block. Get me that number
Re: Early hemi? [Re: The70RTChallenge] #499060
10/16/09 09:09 PM
10/16/09 09:09 PM
moparx Online content
moparx  Online Content
there should be a number pad at the front of the block above the timing cover that will indicate year,displacement,and production #. what are your plans for the intake ?
Re: Early hemi? [Re: moparx] #499061
10/16/09 09:16 PM
10/16/09 09:16 PM
Rancho Cordova, California (Sa...
hemi71x Offline
hemi71x  Offline
RF-4C Phantom 69-370 Zweibrucken, Germany
Re: Early hemi? [Re: hemi71x] #499062
10/16/09 09:23 PM
10/16/09 09:23 PM
Leucadia, Ca.
V
vdriver Offline
vdriver  Offline
V
Leucadia, Ca.
Re: Early hemi? [Re: The70RTChallenge] #499063
10/16/09 10:06 PM
10/16/09 10:06 PM
Vandergrift,PA
Vandergrift,PA
I checked between val. pan and water pump, there is only a raised section of the block no numbers? I will post pictures tomorrow night to help you have a little better understanding.
