crank shield in oil pan for stroker?
#496921
10/14/09 08:30 AM
10/14/09 08:30 AM
Posts: 79 montreal, quebec, canada
jimmy71demon
so my stroker crank rubs on my crank shield in the pan. i took it off and tried to dent it out where i saw the rub marks but its still rubbing. does anyone make a shield for strokers? does anyone have any other ideas? or should i jus keep trying to dent mine out?..... thanks in advance for ur help guys! jimmy ![](/ubbthreads/images/graemlins/punkrocka.gif)
Im goin fast Mom!
Re: crank shield in oil pan for stroker?
[Re: jimmy71demon]
#496922
10/14/09 09:24 AM
10/14/09 09:24 AM
Posts: 7,506 Az
Crizila
Az
Hmmm. Assume you mean windage tray? I used the stock factory tray in my 408 and didn't have a problem? Who's tray are you using and are you using the stock main bolt mounting system?
Fastest 300
[Re: ademon]
#496927
10/14/09 11:31 AM
10/14/09 11:31 AM
jimmy71demon
ah, that never crossed my mind. i could jus put some washers between the windage tray and where the bolt treads in.... thanks ademon! ![](/ubbthreads/images/graemlins/thumbs.gif)
Im goin fast Mom!
