Re: NEON Help! Please.
[Re: geno440]
#496882
10/20/09 12:34 PM
10/20/09 12:34 PM
Posts: 5,127 Chicago Blackhawks
hemicar1971
Chicago Blackhawks
I have a few Questions. What year of motor did you swap too? What year of wiring harness is now in the Car? What PCM are you running. 70 Lbs of fuel pressure seem like a lot, I thought 48lbs was the number. It sounds like you have an injector problem, either with the injectors or through the Harness itself.This is what I can gather without seeing the car.
1971 HEMI E BODY REGISTRY
[Re: hemicar1971]
#496883
10/21/09 07:50 AM
10/21/09 07:50 AM
Posts: 856 1.5 hours SE of Pittsburg, Pa
geno440
The new motor is from a 96. It has 96 stamped on the block.
We changed everything (sensors, etc.) over so that the old wiring harness would plug in.
We used the original PCM plus another one that I got from a scrap yard with the same number as the original.
I have also got a wiring harness from a 95 as well from the scrap yard. I thought we had it made when we put the second wiring harness on. It started and ran pretty good. But within a couple of hours of running it was back to the same situation.
When it started, it threw a code. The code in the Chrysler manual said it was a intermitent loss of timing. It made it sound like the crank or cam sensor was not working. We have replaced both more than once.
The fuel pressure I quoted may not be exactly what we found. I just remember him telling me it was good.
I am really frustrated. I have a good bit of $ in this car and cant get it going.
Love them 68 MOPARS! GTS 340 auto, Charger R/T 440 4-speed, Superbee 383 auto, GTX 440 auto, D100 (new front frame 5.7 hemi - in process), Formula S 340 4-Speed A/C (it's green), 383 auto Roadrunner (maybe a hemi - waiting) and a 68 W200 Power Wagon. Drivers: 07 Cummins and 14 Ecodiesel 4x4.
[Re: B5TA]
#496888
10/21/09 10:22 PM
10/21/09 10:22 PM
hemicar1971
Chicago Blackhawks
The 1995 PCM is unique to 1995 only Neons. It is a single plug harness. The 1996 to 1999 is a two plug harness for the PCM. Like I said in an email go on www.neons.org . All the answers to your question will come from that web site. It is dedicated to Neons only and these guys know their Neon related stuff just like people on here know the older Mopar Performance information.
[Re: hemicar1971]
#496889
10/26/09 07:24 AM
10/26/09 07:24 AM
geno440
Still no luck ...... even posted it on neons.org
[Re: geno440]
#496890
10/26/09 09:09 AM
10/26/09 09:09 AM
Posts: 2,826 NY usa
540challenger
NY usa
Can you keep it running while spraying starter fluid down the throttle. This will at the very less eliminate it being a fuel problem.
[Re: geno440]
#496891
10/27/09 01:21 PM
10/27/09 01:21 PM
Posts: 230 Long Island, New York
Tony H
I'm following this POST. My friend did a Head gasket. The car ran great for about 10 minutes then died. Like someone turned the key. hasn't started since.
'75 CJ5 with all glass body and a 350 Chevy SB '85 Chevy Stepside (the wife's) '89 Volvo All 100% maintained by me. '70 valiant DD for my son '74 Dart Swinger..Latest endeavor http://home.lyse.net/brox/TonyPage4.html
