4 speed (833)?????,s
#496712
10/13/09 11:21 PM
10/13/09 11:21 PM
Posts: 8,859 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
4 speed trans fron a 69 b body first ? i i drained all the fluid so how much do i add back? also what brand/weight do i need to use?(non re built)
the trans is a 69 but the car is a 71b body so what trans crossmember and mount do i need?(shi9fter location has been took care of) ralph
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
Re: 4 speed (833)?????,s
[Re: JohnRR]
#496714
10/13/09 11:58 PM
10/13/09 11:58 PM
toplescuda
I Whine
I Whine
poplar bluff mo.
used the non console(bench seat) for a 71 wich uses a dogbone bracket to relocate the shifter and thay mount off the front pad on a e/b trans(b body only has just the front pad)
[Re: toplescuda]
#496718
10/14/09 09:37 AM
10/14/09 09:37 AM
Posts: 21,088 Niles , Ohio
therocks
Niles , Ohio
For lube just fill it till its at the fill hole.I use regular 80 90 gear oil im mine and Ive had the same trans since 1969.Rocky
Chrysler Firepower
