Re: 727 Front Planet
[Re: ihv800]
#496219
10/13/09 02:02 PM
10/13/09 02:02 PM
with such a bastardized version of a 727 you have now, IMO your better off either buying a new one, or a known good used one.
[Re: ihv800]
#496221
10/13/09 02:14 PM
10/13/09 02:14 PM
oh it an I.S. then yah, it has an early style planet. didn't think the output and tailshafts were that rare, don't early RAMS use the same setup?
[Re: ihv800]
#496222
10/13/09 03:53 PM
10/13/09 03:53 PM
Posts: 25,842 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The easiest way to see if the output shaft and planet splines match is to mount the front planet only on the shaft and shine a flashlight in from the back side, any mismatch will show on the light shining through the front.
[Re: ihv800]
#496223
10/13/09 04:56 PM
10/13/09 04:56 PM
Posts: 28,068 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Isn't the difference in the shape of the splines? I thought the early units used a rounded spline and the later ones went with sharper splines.
[Re: feets]
#496225
10/13/09 07:28 PM
10/13/09 07:28 PM
John_Kunkel
Rio Linda, CA
The difference is in the angle of the individual splines.
The spline included angles are as follows:
'62-'75= 90°
'76-'93= 75°
'94-on= 60°
The spline angles are sometimes expressed as the pressure angle which is half the included angle (45°, 37.5°, 30°)
