Tire and wheel size calculator #495792
10/12/09 09:43 PM
10/12/09 09:43 PM
Warrenton, VA
65Coronet7165 Offline OP
Warrenton, VA
Anyone have a link to a tire size calculator?? One where you can enter a tire size and get the total diameter....I may have a bad tire on my 67 300 and I may have to find a replacement. They no longer make any tires in my current size...245/70x15.
Re: Tire and wheel size calculator [Re: 65Coronet7165] #495793
10/12/09 10:00 PM
10/12/09 10:00 PM
Newfoundland Canada
Mopar1 Offline
Mopar1  Offline
Newfoundland Canada
You could try the Tire Rack. There's a couble of new tires on the bag in the size you have on your car.
Re: Tire and wheel size calculator [Re: Mopar1] #495794
10/12/09 10:07 PM
10/12/09 10:07 PM
Warrenton, VA
Warrenton, VA
Hmmmmmm, I just called Tire Rack this morning and they said they had NO tire available in 245/70x15.
I'll check again, of course...I'd hate to have to spend the money to get a new set of wheels and 4 new tires just because one tire is bad!! Must be a better way, at least in the short term until my 3 other tires are no good.
Here's what I've got...67 300 'vert. 15 x 7 Wheel Vintiques repo Mopar wheels with 245/70x15 Yoko Avid S/T tires on them. These Yokos are very good tires and the size is perfect for keeping my axel ratio and speedo same as it was stock...while getting a better tire and more tread area on the road...
Re: Tire and wheel size calculator [Re: 65Coronet7165] #495795
10/12/09 10:09 PM
10/12/09 10:09 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Try this link:
http://www.miata.net/garage/tirecalcold.html
I use this one all the time at work and at home.
'68 Newport Custom Barge on a Budget!! BOAB
1973 Satellite WAGON! 318- 3 on the tree!!
2008 Chrysler 300c HEMI!
Re: Tire and wheel size calculator [Re: 68Cbarge] #495796
10/12/09 10:11 PM
10/12/09 10:11 PM
Canuckville
68Cbarge Offline
68Cbarge  Offline
Canuckville
Based on the info on the tire calculator,you may have to go with a 2357515 tire to maintain your desired speedo/gearing
Re: Tire and wheel size calculator [Re: 68Cbarge] #495797
10/12/09 10:27 PM
10/12/09 10:27 PM
Warrenton, VA
Warrenton, VA
Thanks CBarge....should have just asked you on the C body site, but this site has a lot more activity...
Re: Tire and wheel size calculator [Re: 65Coronet7165] #495798
10/12/09 10:33 PM
10/12/09 10:33 PM
BDW Offline
BDW  Offline
Re: Tire and wheel size calculator [Re: BDW] #495799
10/12/09 11:37 PM
10/12/09 11:37 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
look on EBAY
