Page 7 of 7 1 2 3 4 5 6 7
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: ksj] #495006
11/26/09 11:25 PM
11/26/09 11:25 PM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
OK, I have a question. On the unlawful 4 link, Why is the pipe that goes to the side frame bracket larger then steps down to the regular pipe size? Does it make the weld stronger?
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: Dos Snails] #495007
11/26/09 11:55 PM
11/26/09 11:55 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Here's my thinking ...
Frame widths vary from one car to the next. In order to have a proper fit on every car they make these slip fit ends so you can weld it exactly where it needs to be to fit properly.
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: Stanton] #495008
11/27/09 12:29 AM
11/27/09 12:29 AM
Orlando Fl
Dos Snails Offline
Dos Snails  Offline
Orlando Fl
I thought about that, I was thinking that it would be stronger than a butt weld or spread the load over a larger base?
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: Dos Snails] #495009
11/28/09 07:09 PM
11/28/09 07:09 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
yes it does make it stronger than a but weld also. good catch I have been studing this product for almost a month. it is truely a good piece to add to your rear suspension.
Thank you
Kiddart
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: Kiddart] #495010
11/28/09 08:07 PM
11/28/09 08:07 PM
Kokomo,IN
StripeHOG Offline
StripeHOG  Offline
Kokomo,IN
out of all these post's I don't see any thing about the Leaf Link setup IMO that is the best working low buck suspention seems to be forgoten now a days but that setup flat works and you could probably built it for under $500
Andrew Brough D372 1969 Dodge Dart GTS 1.43 60'best 6.82 1/8 98mph "the light came on and I ran out of talent"
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: StripeHOG] #495011
11/28/09 08:14 PM
11/28/09 08:14 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
Ive not read through ALL 7 pages so please forgive me if soomeone already did!!!
Can you use the Cal-trac monoleafs on the street?? And do you take out your snubber??
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: MIKES_DUSTER] #495012
11/28/09 08:16 PM
11/28/09 08:16 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
YES and YES
1.39 9.85 - 137 mph
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: StripeHOG] #495013
12/01/09 09:09 AM
12/01/09 09:09 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I have heard alot about this ladder leaf!!?? what does this set up look like do you have pictures or know someone who runs it. I have heard some guys at the trac use this set up but I have never seen it in real life. Would appreciate some pics
Thank you
Kiddart
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: Kiddart] #495014
12/01/09 08:54 PM
12/01/09 08:54 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Here is a good looking three link set up from bigblockdart.com.
http://www.bigblockdart.com/techpages/3link.shtml
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: justinp61] #495015
12/01/09 10:28 PM
12/01/09 10:28 PM
wisconsin
jp66charger Offline
jp66charger  Offline
wisconsin
kiddart1, I don't know if someone tried to answer your fatigue question or not. I am curious about all this as my car is very heavy and too nice to cut up. Want cal tracs set up and may go that way still, but originally they told me I would need to change the leafs every 2,000 miles in a car as heavy as mine(4260). Maybe I'll just twist up another set of SS. (Both front and rear segments are reversed in 2 seasons.) Not wanting to go big budget since I'm now building an A body to go faster and eliminate weight headaches. No budget for 2 race cars as one is tough enough. Wish someone could just tell me what to do but I will start with weighing front and rear weights to see if caltracs will even work for me.
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: Kiddart] #495016
12/01/09 10:46 PM
12/01/09 10:46 PM
St. Croix, US Virgin Islands
David_in_St_Croi Offline
Try to find someone with a Bugeye Sprite (MK1 Sprite) or a Mk 1 MG Midget/MK2 Austin Healey Sprite. They have this type of rear suspension. On the Spridgets the spring is actually a QUARTER elliptic spring. It comes out from a box in the chassis and runs aft to the axle. The spring actually ends at the axle. The upper link is a bar running from the top of the axle forward to the chassis. No reason the spring cannot continue on as a half elliptic, though, like a standard leaf spring on a Mopar.
I know our MK 1 Midget handles great, have never taken it to the drag strip, though. You can see how axle windup will be well controlled.
Later Spridgets have a standard leaf spring setup; I suspect more for cost considerations than it being a better design
https://www.facebook.com/THENEWCDRA
Proud member of the liberal scientific elite
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: David_in_St_Croi] #495017
12/02/09 01:55 AM
12/02/09 01:55 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
A leaf/link is very simple and I think was first used on the Motown Missle, Pro-Stocker, so that is how old it is. The leaf spring is attached to the housing with a pivot below the spring. Tabs are welded to the housing on either side of the spring, that extend below the spring and are bolted to a pivot that is attached to the spring with clamps. This allows the housing to pivot here, as it is not clamped directly to the spring anymore. Now upper 4-link type bars are added and the front mounts were normally placed inside the upper frame rail, right above the springs. So the leafs still hold the car up, the front segment now acts as a lower 4-link bar and the top bars have been added. They do work well, but if you were going to go to that extreme on the fabrication, why not just add coilovers, replace the front leaf segment with a bar and then you you would have a..............what, a setup EXACTLY like the Unlawful setup. If you have the skills to fabricate a leaf link, you can fabricate your own 4-bar setup like the Unlawful deal and this "bolt on" becomes a moot point.
Monte
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: Monte_Smith] #495018
12/02/09 03:01 AM
12/02/09 03:01 AM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
I certainly don't want to upstage someone with Monte's experience,but if I remember correctly the problem with a leaf/link setup aside from the spring bind in the original version, was the main leaf would distort just behind the front eye.
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: don miller] #495019
12/02/09 01:03 PM
12/02/09 01:03 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Exactly, thats why I said if you were going to that extreme on the fab, replace the lower segment with a bar. Some people fail to see the obvious and that is, if all this old school stuff was so great, it would still be used. It was great in its time, because there was nothing like it, now there is better stuff.......use it.
Monte
Re: Caltracs Versus Triangulated system from Unlawfuls [Re: Monte_Smith] #495020
12/02/09 07:14 PM
12/02/09 07:14 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I have almost made my decision. I am really leaning now to a ladder bar set up I did not realize how inexpensive it is, and therre are many companies that offer them. I know I need to use the 32" long ladders add the front cross bar weld a brace to my rearend then the coil over shock brace and done. then the fun part of tunning it in. I do have the skills and the place to do a ladder bar. If i can do my own roll bar, floor pans, quarter panels and rear tail light panels I can weld in a four link. Monte you are a well of knowledge thank you very much for all the info and taking time to teach us a thing or two!!!
Kiddart
Thank you
Kiddart
