Seems the rocker arm stands are wrong for the rocker arms , found some scuffing on the underside of EX rocker arms , this engine was built State side , seems it was tearing the hold down bolts to rocker shaft/stand , the guy who had it before me changed to ARP bolts for this reason , seems the weak link is now the rocker arms , will get hold of the right stands & hope it will fix the problem.
Will pull the stands & see where it's binding , did'nt think of this before now.
, always thought it was due to the adjusters getting too much heat when a few pushrods got hot due to lack of oil with the spray bars , due to the fact the rocker arms are breaking right @the adjusters.
