Re: Cam Suggestions??
[Re: belvedere383]
#494087
10/13/09 09:21 AM
10/13/09 09:21 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
LOL, didn't realize you're in Ohio. I was thinking maybe you were in Lima, Peru. The SRs I had are not as good as what you have. They flow less than 300 cfm out the box (early castings), you said your heads flow 350+. I did have more compression, but you have 40 more cubic inches (1/2" more stroke). I'm not saying my combo ran this much better than yours and trying to make anyone feel bad, just giving you something to compare it too since they have some similarities. You can't really compare dynos, but that motor in my car put 508 hp and about 460 ft. lbs. to the rear wheels on the local DynoJet chassis dyno. I agree with the timing, 30 degrees is too low. You need to be around 36 degrees. CHIP
[Re: Hemiroid]
#494088
10/13/09 09:22 AM
10/13/09 09:22 AM
Posts: 52,972 Romeo MI
MR_P_BODY
If you're only running 30* of timing, that's a lot of where you hp has gone. Set the timing around 36* and I'm sure it will pick up. No worries about timing at 36*-38* with 110 octane race gas.
bump the timing up... should wake it up
[Re: MR_P_BODY]
#494089
10/13/09 10:25 AM
10/13/09 10:25 AM
Posts: 202 Barboursville, VA
belvedere383
Barboursville, VA
I run a Ram clutch, launch at 4700, and I don't really know where I trap, but I think iTs around 6200.
And defiantly no hard feelings I appreciate all the help I can get.
65' Belvedere
496'' Stroker Indy Heads
[Re: LAR_414]
#494091
10/13/09 12:53 PM
10/13/09 12:53 PM
belvedere383
Barboursville, VA
i was slipping the clutch, but if i get another chance to go to the track before it closes i am going to try and be more aggressive.
65' Belvedere
[Re: belvedere383]
#494092
10/13/09 01:01 PM
10/13/09 01:01 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
My thought was since it was a heavy street car a bit more torque would help the car accelerate.I would have limited the cam duration to about 276@.050.The installed cam is fine if the engine can stay in the sweet spot.I The timing should be 34-35 degrees and that will pick the car up alot. Depending on the tires a 4.10-.4.30 would be optimal.I think the others will agree a tall as possible tire is a good idea also.There is enough h.p. to run low 10's if everything is right but I am bit bit leery of the torque output.
Leave the gun.......take the Cannoli's....Mike
[Re: mike s]
#494093
10/13/09 01:06 PM
10/13/09 01:06 PM
belvedere383
Barboursville, VA
it has no problem staying up in the revs, and i run a 28x10.5 goodyear slick. I really think some timing, seat time, and a gear would make my car run like it should.
65' Belvedere
[Re: LAR_414]
#494095
10/13/09 01:46 PM
10/13/09 01:46 PM
belvedere383
Barboursville, VA
I will try that launch technique, the fueling issue though i really dont see it as a problem. The car never loses any MPH, it always goes 123-125. And my fuel pressure stays consistent down the track so i will double check but i think i can mark that off of the list.
I may try and put the cam at 0 or 2* retarded rather than 2* advance and see what that does for me.
65' Belvedere
