Need some help cooling down this 440 #492400
10/09/09 12:13 PM
10/09/09 12:13 PM
Arizona, usa
mcoderoadrunner Offline OP
Arizona, usa
I got the car running after the groups help. It only shoots fire initally and after heating up it stops, but noe the car runs hot enough to cook breakfast on top the manifold covers??? I am thinking to move to a 160 thermostat.... Is this a good idea or is there something else I need to consider?? Thanks Mopart friends.
Re: Need some help cooling down this 440 [Re: mcoderoadrunner] #492401
10/09/09 12:16 PM
10/09/09 12:16 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Lean?? list all your info 1000's of members one small brain!
Re: Need some help cooling down this 440 [Re: Dodgem] #492402
10/09/09 12:27 PM
10/09/09 12:27 PM
Arizona, usa
Arizona, usa
Please tell me how to rich the mixture. Can I do this from the air fuel adjustments on the side of the center carb?? Tom
Re: Need some help cooling down this 440 [Re: mcoderoadrunner] #492403
10/09/09 12:33 PM
10/09/09 12:33 PM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
The stat is not the issue. Overheating is most often do to fuel mixture or timing issues, get those right first. There are lots of got references for setting a/f mixtures, learn to use the search function on this site and refer to the tech archive, these are your friends.
Re: Need some help cooling down this 440 [Re: GTXKen] #492404
10/09/09 12:48 PM
10/09/09 12:48 PM
chatham, Ilinois
fox Offline
super street
fox  Offline
super street
chatham, Ilinois
Take the spark plugs out and take a close up picture of them, post it here and we can tell you if it is lean.
If so you need to see what jets are in it and go 2-3 steps richer and try it.
I had a car doing the same, didn't think it was lean because it ran so well, smooth transitions and all. It would over heat at 55 mph!! richer jets cured it. Power went up and so did mpg.
