Whats the easiest way to tell a 727 from a 904? #492202
10/09/09 07:05 AM
10/09/09 07:05 AM
Rutherfordton NC
BarryBum Offline OP
Fruit Of The Loon
BarryBum  Offline OP
Fruit Of The Loon
Rutherfordton NC
Whats the easiest way to tell a 727 from a 904 when the trans is still in the car??
And would a 71 318 b body automatically have a 727?
Re: Whats the easiest way to tell a 727 from a 904? [Re: BarryBum] #492203
10/09/09 07:12 AM
10/09/09 07:12 AM
Montana
FuryUs Offline
FuryUs  Offline
Montana
Look at the pan rail where the dipstick tube goes in. 904 has a regular, curved 90 degree corner. 727 has a bump out.
Re: Whats the easiest way to tell a 727 from a 904? [Re: FuryUs] #492204
10/09/09 08:01 AM
10/09/09 08:01 AM
Berlin, N.J.
abodyjoe Offline
abodyjoe  Offline
Berlin, N.J.
It's better to keep your mouth shut and give the impression that you're stupid than to open it and remove all doubt.
www.MoparMisfits.com
Re: Whats the easiest way to tell a 727 from a 904? [Re: abodyjoe] #492205
10/09/09 08:50 AM
10/09/09 08:50 AM
Rutherfordton NC
BarryBum Offline OP
Fruit Of The Loon
BarryBum  Offline OP
Fruit Of The Loon
Rutherfordton NC
Thanks guys, that helped a ton.
Re: Whats the easiest way to tell a 727 from a 904? [Re: BarryBum] #492206
10/09/09 10:16 AM
10/09/09 10:16 AM
If your eyeballing it from the top, on a 904 where the 45 degree sloped bellhousing section meets the horizontle main body there is a raised bump all around the circumference at that junction that you can see (or feel) whereas on a 727 this transition is smooth.
Re: Whats the easiest way to tell a 727 from a 904? [Re: RapidRobert] #492207
10/09/09 06:54 PM
10/09/09 06:54 PM
Montana
P
Posest Offline
Posest  Offline
P
Montana
Wasn't there something about the inspection cover bolts, or was that for big and smallblock?
Re: Whats the easiest way to tell a 727 from a 904? [Re: Posest] #492208
10/09/09 09:24 PM
10/09/09 09:24 PM
scratchnfotraction Offline
uhm?? I knew the cover space thing for sb to BB but never thought about 727 to 904??
good ?
most time I dont even have a cover on any of them
