Exhaust stud removal ideas?
#491358
10/08/09 08:38 AM
10/08/09 08:38 AM
Posts: 910 Southern Oregon
toyotajeep
Southern Oregon
It is looking like I will need to remove the studs from my 440 to install it in my A body. I may not be able to get my headers on with the engine in the car.
Anyways, I need all the tricks and tips that you can come up with for removing the studs.
I have tried double nutting with no luck. I am thinking heat is the next step. For obvious reasons, I am not interested in breaking anything off etc.
Heat and a wet rag? Heat and squirt some lube?
Thanks, ROB
1989 Dodge Cummins & 1989 Dodge W-250
Re: Exhaust stud removal ideas?
[Re: buildanother]
#491360
10/08/09 09:16 AM
10/08/09 09:16 AM
toyotajeep
Southern Oregon
That was in a 440 A body with underchassis headers?
I would rather keep the studs since I like them better.
ROB
[Re: Dodgem]
#491362
10/08/09 10:07 AM
10/08/09 10:07 AM
Posts: 15,487 Florida
scratchnfotraction
get some spare heads first just in case they are coming off and going to machine shop for drilling broke ones out heat them up cherry red and sprays some PB Blaster to cool them some,it will wick it in there worked for the last sb I did when they would not move.. good luck
[Re: Dodgem]
#491363
10/08/09 10:08 AM
10/08/09 10:08 AM
RapidRobert
The hot wrench & squirt some lube. You need as much room as possible so nothing is damaged especially in the heat of battle in the tight confines of a big block A body. I also drop the center link & pull the steering col/box.
[Re: RapidRobert]
#491364
10/08/09 11:05 AM
10/08/09 11:05 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
Get a stud remover.Spend 10 bucks and make the job easier.Ive also used bees wax to remove stubbourn bolts etc.Heat with torch and melt wax it draws in and most come out easy.Leave as many studs in if you can.Rocky
Chrysler Firepower
[Re: therocks]
#491365
10/08/09 11:25 AM
10/08/09 11:25 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
Stud remover is well worth the $
[Re: toyotajeep]
#491367
10/08/09 06:13 PM
10/08/09 06:13 PM
Challenger 1
Cincinnati, Ohio
A good stud remover cost more than 15 bucks and gives you way more leverage to remove the stud. I have used at least 3 different kinds with the collet stud remover being the best by far, naturally it cost the most. It can get in tighter places and most importanly, it doesn't damage the stud. When you screw together motors that are held together completely by studs except for the rods you use a good stud setter/remover. Good luck getting them out , the collet tool would do it without breaking them. I've broke em too,(the tool) like the one in my picture. I don't think you can break the collet type tool, it has never let me down. These are all Snap-On. BTW the cam type, the cheapest is just about useless IMO. Many, many studs in these motors. yup those are windows, the motor has been ran many times since the repair and runs the same. Gotta love aluminum and KB
[Re: toyotajeep]
#491368
10/08/09 07:08 PM
10/08/09 07:08 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
ROB
Not exactly, but in an original 383 A body with manual steering and small primary tubes. Probably not a good comparison either.
[Re: BSB67]
#491369
10/08/09 07:30 PM
10/08/09 07:30 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Small/tiny Pipe Wrench and PB Blaster. I own 3 1/2-inch and 5-inch long Rigid pipe wrenches, for just such bolt-removal situations. I also have a Stud-Remover, like the one from Sears above, but if there is room, I use the tiny pipe wrench.
[Re: Lefty]
#491373
10/08/09 08:47 PM
10/08/09 08:47 PM
Challenger 1
Cincinnati, Ohio
http://www.sears.com/shc/s/p_10153_12605_00904458000P
I had never heard of one, might have to check em out.
Better read the reviews first...
I pointed that out in my post above, the cam type stud remover is pretty useless. And if it does get it out the stud is marred. Even with a Snap on brand cam stud tool.
As chessey as it sounds, yea I have used a small 5-6" pipe wrench too when I'm in a hurry and am not gonna reuse the stud.
[Re: toyotajeep]
#491374
10/08/09 09:32 PM
10/08/09 09:32 PM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
ROB
No, it was fenderwell headers on the A body, but it worked on some under chassis B bodies, and worth a shot to me.
[Re: buildanother]
#491375
10/13/09 08:12 AM
10/13/09 08:12 AM
toyotajeep
Southern Oregon
Just some information for anyone searching.
I ended up using the cam type of remover that I got at Shucks. They were the only place I could get to. You people are right, it does ruin the studs etc.
However it worked, and all studs are removed without incident.
Thanks for the tip. Onto the next issue.
ROB
[Re: Lefty]
#491377
10/13/09 09:07 AM
10/13/09 09:07 AM
Posts: 671 Wisconsin USA
Bill MeLater
Wisconsin USA
I've had good luck mig welding a nut on after soaking overnight with penetrating oil. The heat (and current?) seems to break the rust bond and they real easy.
Works every time...Impact helps too.
