71 gtx roadrunner #489597
10/06/09 04:57 AM
10/06/09 04:57 AM
eganville ont
440beep Offline OP
440beep  Offline OP
eganville ont
Did '71 U and V-code B-bodies use H-pipes from the factory? 71 plymouth or dodge
Plymouth's gonna getcha! There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters 71 gtx 440 4speed air grabber blue on blue with white vinyl roof
Re: 71 gtx roadrunner [Re: 440beep] #489598
10/06/09 09:15 AM
10/06/09 09:15 AM
Ont, Canada
gygeneral Offline
gygeneral  Offline
Ont, Canada
The parts book does not show an H pipe.
Re: 71 gtx roadrunner [Re: gygeneral] #489599
10/06/09 09:55 AM
10/06/09 09:55 AM
eganville ont
440beep Offline OP
440beep  Offline OP
eganville ont
426 - 3466116
440 - 3466994 and 3466995
383 4bbl - 3466095 and 3466098
Re: 71 gtx roadrunner [Re: 440beep] #489600
10/07/09 12:06 PM
10/07/09 12:06 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
On the Broadcast sheet for my '71 U-code GTX under the box for LH and RH headpipes, mine shows LH-00 and RH-01. I think the 00 for the LH pipe means no part # assigned as it was an H-pipe assembly... Is there an H-pipe part # ending in 01? My '71 GTX has an old H-pipe on it that sure looks OEM since it has the torsion bar flats and crush spots...
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 71 gtx roadrunner [Re: 70440+6bbl] #489601
10/07/09 11:15 PM
10/07/09 11:15 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
BTT
Re: 71 gtx roadrunner [Re: 70440+6bbl] #489602
10/08/09 06:49 AM
10/08/09 06:49 AM
Highland, Michigan
1972Rallye Offline
1972Rallye  Offline
Highland, Michigan
None ending with 00 that I can see... check the attachment.
Re: 71 gtx roadrunner [Re: 1972Rallye] #489603
10/08/09 10:14 AM
10/08/09 10:14 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
The same for 01 Now I am more confused than ever... Maybe in a vintage '70-1 Parts book?
Re: 71 gtx roadrunner [Re: 70440+6bbl] #489604
10/08/09 10:17 AM
10/08/09 10:17 AM
MN
ryangtogtx Offline
ryangtogtx  Offline
MN
I am almost possitive that they did use an H pipe. If Eric sees this, he would be able to confirm.
Re: 71 gtx roadrunner [Re: 70440+6bbl] #489605
10/08/09 10:23 AM
10/08/09 10:23 AM
Highland, Michigan
1972Rallye Offline
1972Rallye  Offline
Highland, Michigan
That was from a December 1971 (Final Revision) Parts book. Somebody might have an earlier copy...
Re: 71 gtx roadrunner [Re: ryangtogtx] #489606
10/08/09 10:46 AM
10/08/09 10:46 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Eric posted the same #'s as the parts book shows for separate headpipes over on the RR nest. Does anyone have access to a survivor?
Re: 71 gtx roadrunner [Re: 70440+6bbl] #489607
10/08/09 01:41 PM
10/08/09 01:41 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
I have been following this thread and I thought there were other Survivors that would post but I guess not so I crawled under my 71 X which is a survivor and snapped this pic..... this should answer your question if it was stock or not.....
71 GTX 4sp Dana GY9 HD Road King
Re: 71 gtx roadrunner [Re: AZ-Nick] #489608
10/08/09 04:05 PM
10/08/09 04:05 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Nick- great and thanks for the pic. Do you have a Broadcast sheet for your car? If so, what does it show in the EXHAUST box for the headpipes?
Re: 71 gtx roadrunner [Re: 70440+6bbl] #489609
10/08/09 04:14 PM
10/08/09 04:14 PM
Ridgeland Wi
mopars_1 Offline
mopars_1  Offline
Ridgeland Wi
what about a 340 roadrunner?
1971 Plymouth Duster 340 auto
1937 Plymouth PT50
1969 Dodge Dart Swinger 340 4 speed
2013 Ram laramie 2500 hemi
2008 Harley FLSTSB springer
Re: 71 gtx roadrunner [Re: mopars_1] #489610
10/08/09 05:10 PM
10/08/09 05:10 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
No MOPAR 340 cars came from the factory with a "H"-pipe.
Re: 71 gtx roadrunner [Re: 70440+6bbl] #489611
10/08/09 05:26 PM
10/08/09 05:26 PM
Lower AZ
AZ-Nick Offline
Here Since 1996!
AZ-Nick  Offline
Here Since 1996!
Lower AZ
Unfortunately my X came from the LA plant, so my luck in finding a sheet in it was worse odds than my ex-wife becoming a saint and if you know her, then you know that this will never happen.....
Re: 71 gtx roadrunner [Re: AZ-Nick] #489612
10/08/09 10:07 PM
10/08/09 10:07 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
I thought 71s had the H pipe and 72s didnt ? pics are an Hpipe off a 71 GTX ( no I cant prove beyond a doubt its the original) notice the flatened spots in the pics , did a 70 H pipe have these too??
Re: 71 gtx roadrunner [Re: stateline] #489613
10/08/09 10:10 PM
10/08/09 10:10 PM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
another view
Re: 71 gtx roadrunner [Re: stateline] #489614
10/09/09 12:21 AM
10/09/09 12:21 AM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Mine looks just like that with the flat spots, did you remove that pipe from a '71 440 B-body? Is that NOS or a sandblasted original?
Re: 71 gtx roadrunner [Re: 70440+6bbl] #489615
10/09/09 12:43 AM
10/09/09 12:43 AM
Under the big sky
stateline Offline
stateline  Offline
Under the big sky
I took it off a 71 GTX many years ago, Im pretty sure its the factory H pipe that came on the car . I sand blasted it . does a 70 H pipe have the flat spots too , I didnt think so but I cant remember.
Re: 71 gtx roadrunner [Re: stateline] #489616
10/09/09 01:01 AM
10/09/09 01:01 AM
Riverside, Ca
R70RUNNER Offline
R70RUNNER  Offline
Riverside, Ca
I'll chime in with a FWIW, back in the early '80's I had a '71 Charger R/T U code/4spd car that had the original exhaust on it (40K on the on the clock then) it had an H pipe on it. Original Cal car, turn downs/ no tips
