Re: 71 gtx roadrunner
[Re: gygeneral]
#489599
10/06/09 09:55 AM
10/06/09 09:55 AM
Posts: 1,183 eganville ont
440beep
eganville ont
426 - 3466116 440 - 3466994 and 3466995 383 4bbl - 3466095 and 3466098
Plymouth's gonna getcha!
There are 3 things that will live forever, cockroaches, Keith Richards, & slant 6 Dusters
71 gtx 440 4speed air grabber blue on blue with white vinyl roof
[Re: 440beep]
#489600
10/07/09 12:06 PM
10/07/09 12:06 PM
Posts: 5,268 NY
70440+6bbl
NY
On the Broadcast sheet for my '71 U-code GTX under the box for LH and RH headpipes, mine shows LH-00 and RH-01. I think the 00 for the LH pipe means no part # assigned as it was an H-pipe assembly... Is there an H-pipe part # ending in 01? My '71 GTX has an old H-pipe on it that sure looks OEM since it has the torsion bar flats and crush spots...
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5 ‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7 ‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
[Re: 1972Rallye]
#489603
10/08/09 10:14 AM
10/08/09 10:14 AM
Posts: 5,268 NY
70440+6bbl
NY
The same for 01 Now I am more confused than ever... Maybe in a vintage '70-1 Parts book?
[Re: 70440+6bbl]
#489605
10/08/09 10:23 AM
10/08/09 10:23 AM
Posts: 837 Highland, Michigan
1972Rallye
Highland, Michigan
That was from a December 1971 (Final Revision) Parts book. Somebody might have an earlier copy...
[Re: 70440+6bbl]
#489607
10/08/09 01:41 PM
10/08/09 01:41 PM
Posts: 7,906 Lower AZ
AZ-Nick
Here Since 1996!
Here Since 1996!
Lower AZ
I have been following this thread and I thought there were other Survivors that would post but I guess not so I crawled under my 71 X which is a survivor and snapped this pic..... this should answer your question if it was stock or not.....
71 GTX 4sp Dana GY9
HD Road King
[Re: 70440+6bbl]
#489609
10/08/09 04:14 PM
10/08/09 04:14 PM
Posts: 3,106 Ridgeland Wi
mopars_1
Ridgeland Wi
what about a 340 roadrunner?
1971 Plymouth Duster 340 auto 1937 Plymouth PT50 1969 Dodge Dart Swinger 340 4 speed 2013 Ram laramie 2500 hemi 2008 Harley FLSTSB springer
[Re: stateline]
#489614
10/09/09 12:21 AM
10/09/09 12:21 AM
Posts: 5,268 NY
70440+6bbl
NY
Mine looks just like that with the flat spots, did you remove that pipe from a '71 440 B-body? Is that NOS or a sandblasted original?
[Re: 70440+6bbl]
#489615
10/09/09 12:43 AM
10/09/09 12:43 AM
Posts: 1,294 Under the big sky
stateline
Under the big sky
I took it off a 71 GTX many years ago, Im pretty sure its the factory H pipe that came on the car . I sand blasted it . does a 70 H pipe have the flat spots too , I didnt think so but I cant remember.
