Re: Smallblock question, Ryan J or ??
[Re: 40ford]
#488952
10/07/09 12:10 AM
10/07/09 12:10 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Leon, you always get defensive, when I don't jump at what you say. I don't exactly agree with what you say about rings and combos and you get snippy. As far as "have done it"...to be honest, no you haven't, or did I miss the time that you went 5.30s, on a 28x10.5, non W tire, on stock suspension, at 3300lbs, with a smallblock, a cast single 4 intake and a single plate. Exactly when was that? What you, or anyone else did, on larger tires and with ladder bars and 4-links, has absolutely no bearing on this conversation. The cars that compete in this class have the best of the best motors, built by builders such as BES, Bennet, Wilkerson, Huntsville Engine, Kuntz, Pro-Line and many others. You are no going to just throw some old stuff together and run up front. As of this time, only a handfull of these cars have dipped into the high 20s and that took stellar conditions. Tell you what, there is a 10,000 race coming up for these type cars in Feb. Why don't you just throw something together and show us how easy it is.
Monte
[Re: Monte_Smith]
#488953
10/07/09 01:23 AM
10/07/09 01:23 AM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
I think I'm in the minority because I think 900+ will be difficult but not impossible. That's the reason I suggested CFE. If it was easy, everyone would do it Like I said you'll need to "access" at least 380 cfm and everything down to the exhaust tuning and intake runner tuning will have to be spot on! Hope you keep us updated on this project Monte...
Brian Hafliger
[Re: Brian Hafliger]
#488954
10/07/09 01:33 AM
10/07/09 01:33 AM
Monte_Smith
North Alabama
Thanks Brian, I appreciate the honest response and I do know what I am getting into. The class is full of cross breeded cars, owners with plenty of money, and I know a few builders have had the green light to go any direction they thought was best, so if the small Mopar was such a slam dunk, there would be one already. This guy wants to be different and I am like you, I think we can get close to the top guys power wise, but will have to be smart about it.
Monte
[Re: scottb]
#488961
10/07/09 01:07 PM
10/07/09 01:07 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
There isnt any doubt in my mind the R5 heads bolted onto the right shortblock would make 900 ponies.
The problem is, as Scott correctly point out, is that no such block currently exists, except one which has only been " dreamed about" thus far.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: Otherlane]
#488964
02/08/10 08:26 PM
02/08/10 08:26 PM
KOS
Just call ryanj and be done with it that way you cut out of the b.s
[Re: MattW]
#488965
02/08/10 08:45 PM
02/08/10 08:45 PM
Any UPDATE Monty? Matt
I asked Monte about this buildup a month or so ago and the owner decided to go a different direction.......
Wayne
#488966
02/09/10 06:24 PM
02/09/10 06:24 PM
Posts: 2,776 Ontario Canada
MattW
Ontario Canada
Wayne [/quote Thanks for the info! Matt
