9.5" flywheel #488135
10/04/09 04:11 PM
10/04/09 04:11 PM
Tampa , Fl
MoparJoe Offline OP
super gas
MoparJoe  Offline OP
super gas
Tampa , Fl
Is the flywheel on /6's and early V8 A bodys the same for a 9.5" clutch? I think it's the 124 tooth version.
Re: 9.5" flywheel [Re: MoparJoe] #488136
10/04/09 04:41 PM
10/04/09 04:41 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
poss a 273
Re: 9.5" flywheel [Re: 340dart4spd ] #488137
10/04/09 05:16 PM
10/04/09 05:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No, the /6 flywheel will not bolt to an LA crank. I think two bolts are off.As for the rest of the flywheel matching up (tooth count, pressure plate bolt pattern, etc) I dunno.
Don't be the exception.
Re: 9.5" flywheel [Re: Supercuda] #488138
10/04/09 05:47 PM
10/04/09 05:47 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
1 bolt is offset. I have a 340 flexplate on my Slant by elongating 1 bolt hole, so you may be able to use a Slant flywheel on a 273.
Re: 9.5" flywheel [Re: slantzilla] #488139
10/04/09 07:53 PM
10/04/09 07:53 PM
Tampa , Fl
MoparJoe Offline OP
super gas
MoparJoe  Offline OP
super gas
Tampa , Fl
Hmm, I guess I'll have to track down one from a /6 to find out, the actual application is a '68 273/833 Dart, I have I have the bell/fork/linkage/pedals etc from it but the guy who parted the car tossed out the flywheel thinking it wasn't worth anything so I'm trying to track down a replacement.
Re: 9.5" flywheel [Re: MoparJoe] #488140
10/04/09 08:28 PM
10/04/09 08:28 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Be careful, Slant flywheels (and I think SB too) have different size holes in the center for the register on the crank. '68 and up have a larger diameter hole than '67 and down.
Re: 9.5" flywheel [Re: slantzilla] #488141
10/04/09 08:49 PM
10/04/09 08:49 PM
Tampa , Fl
MoparJoe Offline OP
super gas
MoparJoe  Offline OP
super gas
Tampa , Fl
The later one is what I need so it should be easier to track down, I found 5 within 20 miles of my house at salvage yards so I may run down this week with my flexplate and see how far off they are.
Re: 9.5" flywheel [Re: MoparJoe] #488142
10/04/09 10:53 PM
10/04/09 10:53 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I have a flywheel out of a 68 273 4-speed Dart laying in a pile in the barn. If you can't find one soon PM me and I will dig it out. I drive to Hudson, FL a dozen times every year...
JB Rhinehart, Realist
A-Body's RULE!
Re: 9.5" flywheel [Re: slantzilla] #488143
10/05/09 12:10 PM
10/05/09 12:10 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Let's clear this one up right now.
The difference is NOT the outer diameter, which is all that matters fr a manual trans setup.
The difference is the inner diameter where the snout of the torque converter is supported.
This difference applies only to an automatic equipped car, not one with a manual trans. If you happen to have the early, smaller inner diameter crank and whant to run it with a later, large diameter T/C then you can machine the inner diameter out. If you happen to have a later crank with the larger diameter and you need to run it with a smaller diameter T/C then you need an annular ring to make up the difference. I believe Wildcat Auto sells them, among others.
Re: 9.5" flywheel [Re: Rhinodart] #488144
10/05/09 02:42 PM
10/05/09 02:42 PM
Tampa , Fl
MoparJoe Offline OP
super gas
MoparJoe  Offline OP
super gas
Tampa , Fl
Cool I'll keep that in mind, I have Tampa as a general location and I work there but Hudson starts about 250' from the front door of my house.
Re: 9.5" flywheel [Re: Supercuda] #488145
10/05/09 06:11 PM
10/05/09 06:11 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I guarantee that the outer diameter of the register is smaller too. I have 3 small register flywheels in my shop now and they will not fit a later crank.
Re: 9.5" flywheel [Re: MoparJoe] #488146
10/05/09 11:22 PM
10/05/09 11:22 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I will be at my barn tomorrow and am heading to Hudson on Sunday, so let me know soon!
A-Body's RULE!
Re: 9.5" flywheel [Re: Rhinodart] #488147
10/06/09 08:45 PM
10/06/09 08:45 PM
Tampa , Fl
MoparJoe Offline OP
super gas
MoparJoe  Offline OP
super gas
Tampa , Fl
I'm interested in the wheel, sorry for getting back so late but I had a long day at work, Tried to send PM about price and my phone # etc but your PM box is full - Thanks
Re: 9.5" flywheel [Re: MoparJoe] #488148
10/06/09 09:56 PM
10/06/09 09:56 PM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Sorry about that Joe, I will clean out my PM box once again. I got the flywheel at the barn today and will be in Hudson either Monday night or Tuesday morning. I will PM you shortly!
A-Body's RULE!
