exactly how thick spacer for 383 intake on 440?? #487494
10/03/09 09:59 PM
10/03/09 09:59 PM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
i know thay used to sell spacers to fit a 383-400 intake on a 440 motor a buddy at work has to make something for one of his classes so thought this would be something simple and he want to try to mill some so need to know exactly how thick thay were(please no guiessing replys)
anyone??
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: exactly how thick spacer for 383 intake on 440?? [Re: toplescuda] #487495
10/03/09 10:14 PM
10/03/09 10:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It would be easier just to buy a 440 intake. They aren't that expensive.
Re: exactly how thick spacer for 383 intake on 440?? [Re: stumpy] #487496
10/03/09 10:18 PM
10/03/09 10:18 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
he has to make (mill) something on the mill at work for his class project
so scence the spacers are pretty stright foward and he can also use them later if he wants
thats what its gonna be lol
1971 charger
Re: exactly how thick spacer for 383 intake on 440?? [Re: toplescuda] #487497
10/03/09 10:20 PM
10/03/09 10:20 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
He should makethe distributor spacer as his Lathe project...
Re: exactly how thick spacer for 383 intake on 440?? [Re: toplescuda] #487498
10/03/09 11:01 PM
10/03/09 11:01 PM
Tampa , Fl
MoparJoe Offline
super gas
MoparJoe  Offline
super gas
Tampa , Fl
1" per side, it needs spacers on the end seals but I'm not sure on those, one bad part is you have to run 2 bellypans which are expensive anymore.
One of my friends built spacers for his car so he could run the same intake/carb on his 2 motors- a 470 low deck and 496RB.
Re: exactly how thick spacer for 383 intake on 440?? [Re: MoparJoe] #487499
10/03/09 11:28 PM
10/03/09 11:28 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Just one pan and a set of paper gaskets.
Re: exactly how thick spacer for 383 intake on 440?? [Re: MoparJoe] #487500
10/03/09 11:29 PM
10/03/09 11:29 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
I bought two of these from Mancini and their Chrysler Engineering Sale. The ones I have measure .850" (actually measured .851" with the calipers). I seem to remember the .850" dimension from an article in the old Mopar Performance News magazine from many years ago. These have a .030" deep step along the bottom to allow the bathtub valley pan to be trimmed and stuffed under the plates. I don't know if you are supposed to use a gasket on both sides, or just RTV one side to the head?
Floyd Lippencott IV
Re: exactly how thick spacer for 383 intake on 440?? [Re: mr_340] #487501
10/04/09 12:32 AM
10/04/09 12:32 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
thanks guys
1971 charger
Re: exactly how thick spacer for 383 intake on 440?? [Re: toplescuda] #487502
10/04/09 12:36 AM
10/04/09 12:36 AM
Here
DirectSubjection Offline
Tacohead. The First and Only
Here
can't get more precise info than that - Moparts yet again rules!
Ride eternal, shiny and chrome
Re: exactly how thick spacer for 383 intake on 440?? [Re: toplescuda] #487503
10/04/09 01:19 AM
10/04/09 01:19 AM
Wichita Kansas
CH3NO2 Offline
CH3NO2  Offline
Wichita Kansas
383 intakes are a inch shorter than the 440 in width. The ports and the intake manifold bolt holes won't line up no matter how far you raise it.
Engine by DeTar http://www.kansasbadman.com
Re: exactly how thick spacer for 383 intake on 440?? [Re: CH3NO2] #487504
10/04/09 01:24 AM
10/04/09 01:24 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Really??? Better explain that to all the folks that have done it for so many years...
Re: exactly how thick spacer for 383 intake on 440?? [Re: 1_WILD_RT] #487505
10/04/09 10:07 AM
10/04/09 10:07 AM
A Banana Republic near you.
JohnRR Offline
JohnRR  Offline
I'd like to know why ? many lowdeck intakes don't flow as well an RB intake , why put a crappy flowing intake on another motor when there are better intakes available ?
And I agree , the bolt holes will line up with the right spacer , the stage 6 heads require a spacer to install them with the RB intake on an RB block .
Re: exactly how thick spacer for 383 intake on 440?? [Re: JohnRR] #487506
10/04/09 10:27 AM
10/04/09 10:27 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I don't have a good reason why other than the stage 6 heads
Re: exactly how thick spacer for 383 intake on 440?? [Re: 1_WILD_RT] #487507
10/04/09 10:32 AM
10/04/09 10:32 AM
JohnRR Offline
JohnRR  Offline
The stage 6 heads allow the use of an RB intake on a B block , spacers required on an RB block or use the M1 intake made especially for that application .
and my question was retorical
Re: exactly how thick spacer for 383 intake on 440?? [Re: toplescuda] #487508
10/04/09 11:10 AM
10/04/09 11:10 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Get some long bolts for the four corners and run them through the intake into the heads. This'll line everything up and then you can measure exactly how thick the spacers need to be. I'd suggest making them out of a phenolic material to keep the heat out of the intake and the carb.
Re: exactly how thick spacer for 383 intake on 440?? [Re: dodgeboy11] #487509
10/05/09 12:30 AM
10/05/09 12:30 AM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
I recall .850 as well. I thought they did a shootout where a m1 B w/ spacers was better (more hp) than a 440 m1? Can't remember who" they "were, but I'm thinking a mid to late 90s mopar mag...
Re: exactly how thick spacer for 383 intake on 440?? [Re: toplescuda] #487510
10/05/09 08:48 AM
10/05/09 08:48 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
what? Never heard of such an animal and i won't even try one if it was available. i mean you can get a used intake for $50-100.
Coming soon!!!!
Re: exactly how thick spacer for 383 intake on 440?? [Re: toplescuda] #487511
10/05/09 09:55 AM
10/05/09 09:55 AM
Connecticut
Ron_M Offline
Ron_M  Offline
Connecticut
For a project, I would make a Torsion bar remover tool patterned after the miller tool. Or any tools for that matter. The distributor spacer mentioned before is a cool project too.
Common sense is a flower that does not grow in everybody's garden
Re: exactly how thick spacer for 383 intake on 440?? [Re: Mr.Yuck] #487512
10/05/09 10:20 AM
10/05/09 10:20 AM
Indiana
Fury Fan Offline
Fury Fan  Offline
Indiana
I measured my set of Stage6 plates a while back and they were 13/16" == .81".
If your buddy really wants to make a more-useful project -- if drilling at a suitable angle, the spacerplate is just about thick enough to drill for a fuel injector.
If we re-read the OP we can reasonably assume that simply installing a cheap used RB intake on an RB engine will get him an F on this machining class project.
Parts I seek: driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set 16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better. 69-73 C-body caliper brackets and/or splashields Send a PM.
Re: exactly how thick spacer for 383 intake on 440?? [Re: Fury Fan] #487513
10/05/09 12:19 PM
10/05/09 12:19 PM
JohnRR Offline
JohnRR  Offline
WE ??? is there a mouse in your pocket ?
Sounds to ME like someone is taking a machining class and needs a project to make and the OP has a use for this useless project ?
