Has anybody used Summit's fuel line like this one? #485772
10/01/09 10:22 PM
10/01/09 10:22 PM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Summit fuel line for an E-brock
Mines leaking.....I haven't used any plumbers tape(which I was always told that's a bad idea). I'm not positive yet if it's the gauge hole or the fuel line side. It's not leaking at the carb.
Moparlee
Re: Has anybody used Summit's fuel line like this one? [Re: Robbins] #485773
10/02/09 05:45 AM
10/02/09 05:45 AM
NJ
SlimJim Offline
mopar addict
SlimJim  Offline
mopar addict
NJ
I had a leak where the line bolted into the carb on a 1405. The cheapo washers were the culprit.
Re: Has anybody used Summit's fuel line like this one? [Re: SlimJim] #485774
10/02/09 08:39 AM
10/02/09 08:39 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
You don't want to seal the thread on that banjo fitting. The washers/gaskets are supposed to do that. Perhaps replace the washers?
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Has anybody used Summit's fuel line like this one? [Re: CJK440] #485775
10/04/09 03:49 AM
10/04/09 03:49 AM
Joplin, MO USA
Robbins Offline OP
Robbins  Offline OP
Joplin, MO USA
Ok, I used Teflon tape on the gauge and the brass nipple in the end of the Summit line and now no leaks. Hopefully it'll stay that way.
Moparlee
Re: Has anybody used Summit's fuel line like this one? [Re: Robbins] #485776
10/04/09 10:11 AM
10/04/09 10:11 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Plumbers tape should ALWAYS be used on pipe threads (tapered). Never on flared joints.
Of course you have to be careful no tape hangs over the end where it can come off and get itto the fuel system or whatever.
Re: Has anybody used Summit's fuel line like this one? [Re: Stanton] #485777
10/04/09 11:15 AM
10/04/09 11:15 AM
toledo ohio
P
pitbovver Offline
pitbovver  Offline
P
toledo ohio
NPT= pipe dope or teflon tape. Interference fit, Tapered threads
The banjo seals with the copper washers. washers should "smash" (deform) a little, Thus the need to replace them everytime the banjo is pulled apart.
Re: Has anybody used Summit's fuel line like this one? [Re: Robbins] #485778
10/04/09 11:32 AM
10/04/09 11:32 AM
Las Vegas, NV
dodgeboy11 Offline
dodgeboy11  Offline
Las Vegas, NV
Clean that tape off and use thread sealer from a bottle. That tape will start to flake off and end up clogging jets and all sorts of crap. Had a friend that used it on an oil pressure gauge and his gauge quit working. Pulled the gauge off and found a piece of that crap stuck in the tiny hole in the back, pulled it out and the gauge worked fine again. Tape works good on water pipes and things that don't have small passages that can get plugged up, but it has no place on most automotive applications.
Re: Has anybody used Summit's fuel line like this one? [Re: dodgeboy11] #485779
10/05/09 10:50 AM
10/05/09 10:50 AM
Montana
P
Posest Offline
Posest  Offline
P
Montana
There is a blue paste that works well with fuel. I have had to use in the past on my fuel pump.
Re: Has anybody used Summit's fuel line like this one? [Re: Posest] #485780
10/05/09 11:40 AM
10/05/09 11:40 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
If the 2 washers on either side of the banjo don't seal, no amount of tape or pipe dope will help.
The threads do not do the sealing with this type of connection so don't waste your time. Fix it right. Look for scored or cracked washers or burrs/cracks on the fitting itself.
Re: Has anybody used Summit's fuel line like this one? [Re: CJK440] #485781
10/05/09 02:34 PM
10/05/09 02:34 PM
scratchnfotraction Offline
I have run those a couple times
right now I have the duel feed line for a thunder carb and drilled the performer top on the other side and tapped it to work
had to put a little tape on the gauge threds on the single line once...
washer every time its R&R for sure
must have got it if its no leaky now
