Cosmoline for preservation #484909
10/01/09 06:16 AM
10/01/09 06:16 AM
Portland Oregon
JohnnyBeGood Offline OP
Portland Oregon
I would like to know if cosmoline is a good product to preserve my blocks,cranks,heads! from rust and corrosion until I am ready to build which could be a while! Any other good stuff to use out there? Thanxs
Re: Cosmoline for preservation [Re: JohnnyBeGood] #484910
10/01/09 08:00 AM
10/01/09 08:00 AM
NY usa
540challenger Offline
NY usa
Cosmoline is one of the best IMO but how long are you talking about storing the parts.
If only for a month or two i would just used motor oil or wd-40 on them and respray/oil themup every2-3 days.
If long term storage is what you got to do then i would cosmoline it but keep in mind you will need a machine shop to boil off the cosmoline when ready to put the motor together.
Re: Cosmoline for preservation [Re: JohnnyBeGood] #484911
10/01/09 08:06 AM
10/01/09 08:06 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I don't see why not. I didn't think it was manufactured anymore. I spray inside and out with WD-40 and seal them up in bags. A company I used to work for sprayed their rebuilt rears and trans (gears) with a lithium grease then top coated it with a spray graphite before storing.
Re: Cosmoline for preservation [Re: redraptor] #484912
10/01/09 09:58 AM
10/01/09 09:58 AM
Athens, Greece
Pyper70 Offline
Pyper70  Offline
Athens, Greece
I spray with a silicone rust inhibitor. LPS its called. I bought a few cans a decade ago....I lathered up my crank, block, pistons, and bores with it....Carb spray it all when it comes time to build...It doesnt dry...always has a wet look and feel to it.
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
Re: Cosmoline for preservation [Re: JohnnyBeGood] #484913
10/01/09 10:48 AM
10/01/09 10:48 AM
I mix solvent and motor oil in a cheap plastic spray bottle & saturate every surface. Works for me & is cheap.
Re: Cosmoline for preservation [Re: RapidRobert] #484914
10/01/09 10:53 AM
10/01/09 10:53 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
wipe it down with straight motor oil. WD40 dries up and stops working after awhile....so wipe heavily with motor oil, bag it, and store it somewhere dry.
you'll be fine!
**Photobucket sucks**
Re: Cosmoline for preservation [Re: JohnnyBeGood] #484915
10/01/09 11:02 AM
10/01/09 11:02 AM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Grease and a paint brush should last a lifetime
Re: Cosmoline for preservation [Re: JohnnyBeGood] #484916
10/01/09 01:05 PM
10/01/09 01:05 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
I use Boeshield T9. Boeing developed it to store aircraft parts. It works great.
http://www.boeshield.com/why/why_t9.php
Re: Cosmoline for preservation [Re: Lefty] #484917
10/02/09 01:05 AM
10/02/09 01:05 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Cosmoline is available at Mcmaster Carr in spray cans or gallon cans.
I can be removed with WD 40 or soapy hot water.
Re: Cosmoline for preservation [Re: sthemi] #484918
10/02/09 02:02 AM
10/02/09 02:02 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I just coat with clean motor oil and seal in bags.
