Anyone else getting a Missile Dry Sump? #484628
09/30/09 07:27 PM
09/30/09 07:27 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I'm ordering my dry sump pump and
Mr. Lanius said that there is a discount on at least three orders
so if anyone wants to join PM me
if not, it's cool
just throwing this out there
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Anyone else getting a Missile Dry Sump? [Re: RylisPro] #484629
09/30/09 08:54 PM
09/30/09 08:54 PM
Ripley
BryanRad Offline
BryanRad  Offline
Ripley
Rough idea on price?
Re: Anyone else getting a Missile Dry Sump? [Re: BryanRad] #484630
09/30/09 08:57 PM
09/30/09 08:57 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Then you need to build a pan...So what do one of those run?
Re: Anyone else getting a Missile Dry Sump? [Re: Dragula] #484631
09/30/09 09:22 PM
09/30/09 09:22 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I'm not getting my pan just yet, not sure what will fit an AlterKtion
I am gonna experiment with a steel rear sump pan and WHEN I screw that one up
I'll get a custom one from Williams Performance which runs about $450.
Missile has their own pans as well
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Anyone else getting a Missile Dry Sump? [Re: RylisPro] #484632
09/30/09 09:31 PM
09/30/09 09:31 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
So here's a bump, and curious to what your pic shows, an alum World BB with 4/1 Stage pump driven from the normal bb oil pump location?
Re: Anyone else getting a Missile Dry Sump? [Re: jcc] #484633
09/30/09 09:47 PM
09/30/09 09:47 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
actually that's a KB block with the older Missile Dry Sump with Razor components.
Steve Lanius manufactures his own pumps now and I think they are anodized red.
His pumps can come in any configuration and uses the cam gear to drive it in the stock location
here is his site:
http://www.missileent.com/
and he would have more info
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Anyone else getting a Missile Dry Sump? [Re: RylisPro] #484634
10/01/09 01:21 AM
10/01/09 01:21 AM
FRANCE / PARIS
NENE Offline
NENE  Offline
FRANCE / PARIS
What does it cost, I wish to swap my KB wet pump to a dry sump system soon
'70 Cuda with a 572 Keith Black / B1 heads with a sheetmetal intake (2 dominators) Lencodrive 3 speed trans. 2350 lbs with me Run 8.04" / 168 mph 1.11" 60 ft Fastest Mopar at the Euro Mopar Nats website : http://vantastic-racing.com/
Post deleted by Defbob [Re: RylisPro] #484635
10/01/09 03:27 AM
10/01/09 03:27 AM
Post deleted by Defbob #484636
10/01/09 04:29 AM
10/01/09 04:29 AM
Re: Anyone else getting a Missile Dry Sump? [Re: NENE] #484637
10/01/09 01:08 PM
10/01/09 01:08 PM
oh
julian2007 Offline
julian2007  Offline
oh
I have one its a little over 2000.00 depending on what stage you buy
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: Anyone else getting a Missile Dry Sump? [Re: julian2007] #484638
10/01/09 01:33 PM
10/01/09 01:33 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Mr. Lanius quoted me a hundred less for my 4 stage
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Anyone else getting a Missile Dry Sump? #484639
10/01/09 01:36 PM
10/01/09 01:36 PM
oh
julian2007 Offline
julian2007  Offline
oh
Its not how much it pumps Its how it does it. I'm told a conventional pump kind of smashes the oil creating heat and small air bubbles and this is what they say is what burns your oil and wheres it out.A dry sump has head pressure on the pump thus eliminating the need for such tight clearances and not smashing the oil.IT will also act like a vacuum pump (less oil leaks) also by the time you buy the pump 2000.00 pan 500.00 tank 550.00 filter 150.00 plum it 1000.00 scavenge filters 40 each x? You put about 5000.00 into the economy and you can say you did your part in helping your country out of economic bad times.
Re: Anyone else getting a Missile Dry Sump? [Re: RylisPro] #484640
10/01/09 01:37 PM
10/01/09 01:37 PM
oh
julian2007 Offline
julian2007  Offline
oh
Good deal!!
Post deleted by Defbob [Re: julian2007] #484641
10/01/09 04:34 PM
10/01/09 04:34 PM
Re: Anyone else getting a Missile Dry Sump? #484642
10/01/09 11:26 PM
10/01/09 11:26 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
fancy system but you don't see it in use very much. there's a ton of Hemi motor builders that pass on it.
I'm gonna use it for road racing
offer is going going...
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Anyone else getting a Missile Dry Sump? [Re: RylisPro] #484643
10/02/09 04:09 AM
10/02/09 04:09 AM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
not that it isn't a interesting or good system i can't say either way but one thing i don't see mentioned is how much these systems load the drive. i have to question the amount of load these big and bigger pumps put on the drive. in just a standard type configuration you're changing drive direction once at the cam to the drive with the missile you're changing it twice. again i'm not commenting on any of these systems as far a quality just drive loading. yes a dry sump is an improvement but how much and at what cost? for a road race application there's more of a need than for drag race. another thing to consider is just how much oil the engine really needs. if you're holding the relief valve open all the time you're just pumping oil in circles heating it up and wasting HP. as for the "smashing oil" theory i've worked around pumps for a long time and have a hard time buying that one. there are different types of pumping elements that do affect efficiency but any positive displacement pump is going to "smash" the oil that's how they work.
Re: Anyone else getting a Missile Dry Sump? [Re: jamesc] #484644
10/02/09 08:07 AM
10/02/09 08:07 AM
oh
julian2007 Offline
julian2007  Offline
oh
I am not saying that is how it exactly is this is what I was told by an aircraft engineer he said it is the only thing to use.As far as the load goes I don't know but I can tell you it put et on my car.Also I have been using it all year and my oil looks as new as the day I put it in,but I have used conventional systems for 20 years without failure, I just thought it was time to step up and go to something better. Who knows for sure
Re: Anyone else getting a Missile Dry Sump? [Re: julian2007] #484645
10/02/09 03:30 PM
10/02/09 03:30 PM
jamesc Offline
jamesc  Offline
don't get me wrong it is one slick looking setup and i actually like the idea of driving it from the stock drive as it's one less thing taking up space on the front of the engine. i just wonder what kind of load it puts on the drive. i also like the idea that in some cases the dry sump setup may/will pull enough that a vacuum pump isn't necessary which with this setup would be even better yet. trying to get everything on the front of a dragster can be even worse than a door car. alternator, vacuum pump, belt drive distributor, crank trigger, dry sump, cooling system, belt drive fuel pump... it's a mess. if you could use this to do the oiling and vacuum it would certainly free up some precious space in front. that said then you need to find a place for the sump tank.
Re: Anyone else getting a Missile Dry Sump? [Re: RylisPro] #484646
10/02/09 04:25 PM
10/02/09 04:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
A road racing dry sump KB alum Hemi? , be sure and flash your lights and I'll move over
Re: Anyone else getting a Missile Dry Sump? [Re: jamesc] #484647
10/02/09 04:30 PM
10/02/09 04:30 PM
oh
julian2007 Offline
julian2007  Offline
oh
I have been told if it is set for a dry sump it can make pretty good vacuum mine does not make muck about 6 inches but they say installing your crank seals backwards makes a difference.My tank is on the cockpit explosion shield along with the air bottle, oil filter,two step and the kitchen sink.
