Post deleted by Defbob
[Re: challenger73400]
#480999
09/27/09 10:34 AM
09/27/09 10:34 AM
[Re: bonefish]
#481001
09/27/09 11:15 AM
09/27/09 11:15 AM
Re: What's the trick to keep flex plate bolts tight?
[Re: VernMotor]
#481004
09/27/09 11:42 AM
09/27/09 11:42 AM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I have a jw adapter and 6 bolts. red loctite here also no issues at all.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#481005
09/27/09 01:21 PM
09/27/09 01:21 PM
Posts: 6,295 U.S.
moparniac
U.S.
How much do you guys torque them to.... ARP stuff.....
Mopar Performance
[Re: bonefish]
#481006
09/27/09 01:29 PM
09/27/09 01:29 PM
Posts: 149 OH, USA
Torred
OH, USA
i have found that if i ignor the torque specs and just tighten the holy crap out of them they stay tight,and i use the red loctite.
[Re: Torred]
#481008
09/27/09 01:38 PM
09/27/09 01:38 PM
Posts: 7,348 Mt.Vernon ,Ohio
VernMotor
Mt.Vernon ,Ohio
Same here.. beat them tight with a hammer and a wrench..been doing that for 25 years.. I know we will have all them guys coming on here O-no thats not right! boo hoo..It works.. beside geting a torque wrench up there is a real pain too.
#481010
09/27/09 03:16 PM
09/27/09 03:16 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
Try red Loctite. X2
[Re: Diablo]
#481013
09/27/09 03:47 PM
09/27/09 03:47 PM
Posts: 976 ontario canada
mac56
ontario canada
Dont want to be a downer but you might have a cracked crank shaft. I couldn't keep mine tight on the new engine. Ended up having a cracked crank. I didn't want to believe what some were telling me but i took the crank out and had it tested. Didn't want to loose my entire 636ci engine due to someone lying about the crank being checked. Better safe than sorry. I acted safe and probably saved my engine from turning into a BOMB!
Doug I never read that was what ended up being your problem. Sorry to hear that. I hope with all the issues you have had this season getting that monster running your are laying a smack down on those chevies.
[Re: W5DART66]
#481015
09/27/09 05:44 PM
09/27/09 05:44 PM
Posts: 303 southwest Alabama
challenger73400
southwest Alabama
What balancer is on engine?
440 source SFI balancer. No unusual vibrations.
Thanks guys, I'll put red lock tight and some bowinkle on the bolts!
BTW. how does a cracked crank cause the flex plate bolts to come loose? Added vibration?
