Re: Ported edelbrock heads.......pics
[Re: Brian Hafliger]
#48027
11/24/07 07:28 PM
11/24/07 07:28 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
This is getting good. Both you guys do really good work and I say this with experiance based on Brian doing head work for my friends cars and my own personal stuff and then with Jeff working his magic with Bob Mazzolinis and Ken Etters stuff for Super Stock. All the cars that I have seen with Brians head and Jeffs heads are FAST! To both guys keep up the good work! Look forward to reading both of your posts at any given time.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
#48028
11/25/07 11:24 AM
11/25/07 11:24 AM
Posts: 1,752 detroit area
moderncylinder
detroit area
sure you could have 3psi of pressure on the back side of the intake valve,, depends on the combo, rpm range, really just about everything that has to do with the engine. really when you get to looking at a depression, and trying to effectively filling a cylinder,, it takes a free or good flowing head which is usually larger in cross section therefore you need to try to evenly pull on the port with how the piston comes off tdc. alot of guys think the rod connects the crank to the piston, but it will dictate the rate of accleration the piston will decend till the mid point of the cylinder, which is the same for any rod. usually this is a rod ratio of 1.65-1.7, dependning on the storke respective to the port cross section again, that can be changed to help an rpm range thats desired to run, or able to be run, we all want to run it as high as you can without the valve train blowing up.
another thought with sheet metal manifolds,,, its common knowledge that you should contain your swept volume at whatever efficiency your engine will run at,, i usually say 115%,,, in the runner so that your complete mixture that will end up in the cylinder has the initial inertia of being in the runner when the valve first opens to get maximum pressure effecting on the cylinder. by working on volumes in manifolds like that its crazy how much power you can gain,, for every degree of intake valve timing that i can hold it open longer ill get about 7hp. but for an engine like a pro stock, its closer to 12hp,, when you consider how much piston movement 1 degree is you understand how tempermental the pressures are and how a little bit,, can be a whole lot.
did i run on??,, i had a late night
jeff
[Re: moderncylinder]
#48029
11/25/07 11:56 AM
11/25/07 11:56 AM
Posts: 9,924 Weddington, N.C.
Streetwize
Weddington, N.C.
I had lunch with David Vizard not long ago and we discussed this tuning a little bit, I asked him specifically about cylinder filling particularly as it related to long intake durations where the valve is closing well past BDC and the piston is rapidly moving back up the cylinder removing effective displacement with every degree. He mentioned the one fact that manyt people don't completely comprehend...something a motor depends on but we're not really concieous of...the fact that air has mass and a column of air mass in motion has momentum. The very notion that VE's can exceed 100% in a race engine is testament to that fact. You also see and understand how variables in the air density effect power output if there is more or less pressure in the intake tract. What dry flow benches do not take into account is the fuel atomization and if or how it stays in suspension at various RPM (proportional velocities) through the powerband, Also it's imprtant to realize that with an example 12.5:1 A/F ratio, ~7.5% of the potential flow is displaced by the fuel the air is carrying in suspension...especially in a carburetted motor. to muddy the waters further, on a bench we tend to only look at air moving one way (either into or out of the cylinder)...the effects of reversion when the rapidly moving column of air suddenly gets the door slammed shut as the valve closes and has to regain it's momentum. Then you think that all the airflow moving through an engine in a minute's time when we know that any intake or exhaust valve is closed roughly 2/3'd of the time....regardless of crankshaft RPM this is a mechanical constant.
#48031
11/27/07 07:50 AM
11/27/07 07:50 AM
Posts: 702 OZ
CRIKEY
super gas
super gas
OZ
[Re: sshemi]
#48033
11/28/07 03:11 PM
11/28/07 03:11 PM
Posts: 5,487 SoCal
Brian Hafliger
SoCal
If i would like to change the intake valves to 2.05" what length or maybe even a partnr. Is it worth much?
Yes, the bigger valve is worth it. The edelbrock bowls are big enough with some amount of work that the bigger valve is worth the extra dollars. It's not just the valve, it's what you do with the seat, bowls, chamber, etc...that makes it so much better. Just cutting the seats and using a bigger valve is not the way to do it!
[Re: sshemi]
#48037
11/28/07 05:44 PM
11/28/07 05:44 PM
Posts: 4,595 On the south side of Nowhere
S/ST 3040
You dont happen to have a partnr of the one you preffer to use?
Ferrea #F6114 has the same specs as their Edelbrock replacement valve in the 6000 series, other than 2.055" diameter.
[Re: sshemi]
#48039
11/29/07 10:20 AM
11/29/07 10:20 AM
S/ST 3040
How much gain could i expect from upgrading to 2.055 valve?
I'm not sure exactly what you can gain as far as CFM. The factory SB Edelbrock intake bowl is pretty big and throat is over 90%. By going to a 2.05" valve, it allows you to cut a completely different seat with the extra material. It also slightly steepens the approach to short turn and gives you more curtain area throughout the lift cycle. I don't like the Edelbrock chamber, as it has flat chamber and very pronounced corner adjacent to the intake valve that I find is nearly impossible to fix without blowing the chamber past the bore it will run on. A 2.05" valve makes this close proximity even worse.
Can you gain by adding the bigger valve? Yes.......but, there is more air flow to be gained further back in the port. I'm sure Brian or Ryan will have something to add.
[Re: sshemi]
#48041
11/29/07 03:24 PM
11/29/07 03:24 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#48042
11/29/07 03:25 PM
11/29/07 03:25 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#48043
11/29/07 03:26 PM
11/29/07 03:26 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#48044
11/29/07 03:27 PM
11/29/07 03:27 PM
Posts: 2,128 sweden
sshemi
sweden
[Re: sshemi]
#48045
11/29/07 04:23 PM
11/29/07 04:23 PM
S/ST 3040
Tell me have I ruined these heads?
Can I think it, without saying it?
Seriously, I'm inclined to think you may have compromised the structure of the head, despite any air flow improvements you have gained.
That's a lot of meat out of the straight wall.
What are your flow numbers?
