Bulletproof head gaskets for 12.5 small block
#479207
09/25/09 01:39 PM
09/25/09 01:39 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I'm building about a 12.5:1 340 stroker and don't want to push out headgaskets.
I know people will recomend cometics but after my last experience I won't use them again, at least not on an LA motor.
I did end up using SCE Titan ICS coppers which worked well and will have no problem dealing with the compression but they are $$
Any composites up to the task??
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: Bulletproof head gaskets for 12.5 small block
[Re: mod5v]
#479209
09/25/09 05:23 PM
09/25/09 05:23 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I run cometics on everthing. Especially small block mopars. Grant it you can't square the surfaces with a belt sander and expect them not to leak. LOL
Leon
[Re: Leon441]
#479210
09/25/09 05:34 PM
09/25/09 05:34 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
Cometics here for 7 years at 13.3 compression zero head gasket failures.I am flat out sold on them
I have had many failures at less compression with 1008 fel pro's.
if the surfaces are prepped correctly, i wouldnt run anything but cometics on a 10 bolt head.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: B3422W5]
#479211
09/25/09 05:37 PM
09/25/09 05:37 PM
Posts: 12,675 Columbia, CT
moper
Columbia, CT
With a true 12.5:1 and using bolts to hold it (stock ones, yes?) I think the best gasket you can get would be the choice. Why not just use what worked before?
[Re: toddd]
#479213
09/25/09 06:20 PM
09/25/09 06:20 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I am running felpro 1008 at 12.5-1 with head studs no problems so far
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: DaKuda]
#479216
09/25/09 08:35 PM
09/25/09 08:35 PM
Posts: 2,327 Glendale, AZ
69L78Nova
Banned. Forever.
Banned. Forever.
Glendale, AZ
I ran 1008s for 7 years at 13 to 1, 7500rpm. No problem
1969 Nova 454/M21/3.31 Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD 5.0/4R70W/3.55 (Daily driver)
