What is the best intake for this 340 engine #477600
09/23/09 02:49 PM
09/23/09 02:49 PM
VA
Fire In The Sky Offline OP
VA
What is the best intake manifold for this 340 engine:
1971 340 Duster engine with Edelbrock/Carter 600cfm carb, aluminum heads(non ported) stock compression (10.5:1) Mopar Purple Cam hydraulic 248 duration,.508 lift, Hooker comp headers, 391 rear gear ratio. Had a Weiand on it for 20 years & looking to get the best aluminum for this setup.
On 15 inch rims with 275's in rear & 235's up front. Streetable with possible drag strip every now & again. Thanks for any help, Jo
Re: What is the best intake for this 340 engine [Re: Fire In The Sky] #477601
09/23/09 02:55 PM
09/23/09 02:55 PM
Raleigh, NC
j.mcconnell Offline
j.mcconnell  Offline
Raleigh, NC
eddy rpm air-gap
Re: What is the best intake for this 340 engine [Re: Fire In The Sky] #477602
09/23/09 02:55 PM
09/23/09 02:55 PM
clarks summit pa
73cuda340 Offline
73cuda340  Offline
clarks summit pa
Either a LD340 or the Edlebrock RPM Air Gap are great intakes.
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: What is the best intake for this 340 engine [Re: Fire In The Sky] #477603
09/23/09 02:55 PM
09/23/09 02:55 PM
Edelbrock Air Gap,run one on both my 416 and 360 with very good results..
Re: What is the best intake for this 340 engine #477604
09/23/09 02:58 PM
09/23/09 02:58 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
LD340 and do yourself a favor put a holley 750 at least on it... it will be a hot one.. dan
Re: What is the best intake for this 340 engine [Re: j.mcconnell] #477605
09/23/09 03:00 PM
09/23/09 03:00 PM
an8sec70cuda Offline
eddy rpm air-gap
CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: What is the best intake for this 340 engine [Re: Fire In The Sky] #477606
09/23/09 03:06 PM
09/23/09 03:06 PM
Indiana, Just Off I-70
BradD Offline
BradD  Offline
Air Gap!!!
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG
Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
Re: What is the best intake for this 340 engine [Re: Fire In The Sky] #477607
09/23/09 07:44 PM
09/23/09 07:44 PM
wilmington,ohio
O
ohiodemon Offline
ohiodemon  Offline
O
wilmington,ohio
Air-Gap
u definately need that 750 dp.
Re: What is the best intake for this 340 engine [Re: ohiodemon] #477608
09/23/09 08:13 PM
09/23/09 08:13 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
LD340 Save some $$ and be happy with the performance too.
LD340 equiped:
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: What is the best intake for this 340 engine [Re: MoparforLife] #477609
09/23/09 08:16 PM
09/23/09 08:16 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Air Gap and get a Thermoquad, you'll love it and all the stock stuff works on them.
Re: What is the best intake for this 340 engine [Re: ScottSmith_Harms] #477610
09/24/09 08:54 PM
09/24/09 08:54 PM
Willoughby Hills, Ohio
gd9704 Offline
super gas
gd9704  Offline
super gas
Isn't the Air-Gap a square bore intake?
Re: What is the best intake for this 340 engine [Re: gd9704] #477611
09/24/09 09:00 PM
09/24/09 09:00 PM
scratchnfotraction Offline
x2 LD340 is on par with air gap rpm intake
