Re: Pros and cons of the Dodge Rampage's?
[Re: chrisf]
#477165
09/22/09 11:49 PM
09/22/09 11:49 PM
Posts: 650 USA
Rollin Hand
USA
[Re: Sidewinder]
#477166
09/22/09 11:54 PM
09/22/09 11:54 PM
Posts: 165 Madison WI
Sublime69
Madison WI
The only thing I can add is most I believe are the 2.2 motors, which I've heard are hard on head gaskets...
On the bright side, a 2.2 turbo would be pretty cool in one, but I like all Mopars, especially the different ones
1969 Dodge Superbee - Original plain jane green 318 Coronet now Sub-Lime, 383 4 speed clone.
[Re: chrisf]
#477168
09/23/09 01:07 AM
09/23/09 01:07 AM
Posts: 1,692 Seattle WA
RichV
Seattle WA
psssssst...its a K car
Sorry it is not a K car its a L body.
[Re: Jim_Lusk]
#477170
09/23/09 01:42 AM
09/23/09 01:42 AM
[Re: RichV]
#477171
09/23/09 01:48 AM
09/23/09 01:48 AM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
And, there's nothing wrong with K-cars, either....
[Re: Jim_Lusk]
#477172
09/23/09 01:56 AM
09/23/09 01:56 AM
[Re: Sidewinder]
#477178
09/24/09 02:51 AM
09/24/09 02:51 AM
DaytonaTurbo
Manitoba, Canada
Check out the floors under the drivers and passengers feet. This is the first area to rot out on these things. Also check out the lower 1/4 panels behind the rear tires are well as the rear wheel openings in the 1/4's. There is NO reproduction sheet metal out there for these vehicles so starting with a rotten one is a bad idea.
Motors and transmissions are pretty good, I've never had to do a head gasket on one, and I overheated one pretty good and suffered no ill-effects. I find they run well, but like said the stock carbs tend to be an issue. Weber makes a nice carb 32/36 or something like that. It's been a while. Actually the stock holley carb is a licensed weber design modded for emissions.
Biggest con is in stock form neither the motor nor transmission have any performance potential. The DC supercharger kit like the one pictured are very hard to find and pricey, plus they don't put out much power. Their auto and manual transmissions won't take much abuse at terribly higher than stock hp levels and require a shifter mod to make a later 80's daytona/other turbo car transmission work. If you want to go turbo you have to find an engine wiring harness from a 87 or prior turbo L body charger or omni. The later years use a different bulkhead connector and IIRC 88 was the changeover year, although the later harness will work if the later dash harness is also swapped in.
My brother's got one he's been slowly fixing up. Bit of a pain in the butt to work on being so tight under the hood.
In all honesty if I ever wanted one, I would get one with a manual trans, put a shelby charger 2.2HO carb spark computer in it and a weber carb and drive it and a fun little economical cruiser instead of doing the whole efi/turbo conversion.
[Re: Sidewinder]
#477181
09/26/09 01:43 AM
09/26/09 01:43 AM
DaytonaTurbo
Manitoba, Canada
The floor boards in the Rampage I'm looking at are toast.The rest of it is pretty solid except for the rear bottom fenders which are showing rust.The rest of the body even the bed are in good shape.Are the floor pans very hard to replace if I can find a donor car floor pans?What other cars floor pans is the same as the Rampage other than the Charger and Omni?Thanks to everyone who has given there info. here.
Floor pans are not the easiest to replace and there are no repros out there. Donor cars include charger/turismo/omni/horizon/scamp gt.
FWIW, if you look on ebay, solid, rust-free, good running daily driver rampages can be had for 1-2k all day. Not worth the time/effort to save a few bucks by buying a fixer upper when the good ones aren't worth anything.
[Re: DaytonaTurbo]
#477182
10/11/09 09:01 AM
10/11/09 09:01 AM
I have an 83 Rampage, std trans. I found an 89 LeBaron GTS w/auto w/a 2.2L turbo as a donor car. What issues would I have to face besides swapping out the engine? I have to deal w/California emissions. O2 sensor, pressurized fuel, is my current exhaust system adequate after the swap, wiring, cooling system w/radiator and fan, adding the brain box are all things that I am concerned about.
