I hate my Holly fuel pump! #476670
09/22/09 03:34 PM
09/22/09 03:34 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
While I'm upgrading things, I have to do something about my Holly electric pump. It's obnoxiously loud and I'm contemplating going w/ a mechanical. It's hooked to a 500 ci wedge in a '68 Charger that will mainly see street duty with maybe a trip to the track a year. For my purposes, would the Carter Super Strip pump be sufficient? (With that, a question: the description states in has 1/4" inlets - does that seem awfully small for a performance pump? I have 3/8" fuel line btw...)
If not this pump, is there one to recommend that would do the job?
Thanks!
Re: I hate my Holly fuel pump! [Re: slowpoke] #476671
09/22/09 04:21 PM
09/22/09 04:21 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
Any high perf mech pump should work good.
If the buzz is to loud then try the Carter, Eddie
or any one of the mech pumps. They can pump
enough fuel for a 600 H P or better motor.
Snap your neck, mega G-force launch, is all I want!
Re: I hate my Holly fuel pump! [Re: slowpoke] #476672
09/22/09 04:23 PM
09/22/09 04:23 PM
Az
Crizila Offline
Crizila  Offline
Az
Yes, that pump is too small for your application. Suggest a Holley HP125 or HP150. These are gerotor pumps - quiet and will deliver the fuel you will need for that 500 incher.
Fastest 300
Re: I hate my Holly fuel pump! [Re: slowpoke] #476673
09/22/09 07:16 PM
09/22/09 07:16 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I replaced my loud Holley blue pump earlier this year with one of their new gerotor pumps. I measured its output to my carb and it was basically the same as the old pump. But it is a lot quieter and more of a whirrrr rather than a growl.
Master, again and still
Re: I hate my Holly fuel pump! [Re: DaveRS23] #476674
09/22/09 08:05 PM
09/22/09 08:05 PM
SE Michigan
farmington Offline
mopar addict
farmington  Offline
mopar addict
SE Michigan
Back when Bob Glidden ran a plymouth Arrow in pro stock (and was the champ) he used two stock Holley blue pumps. With the proper fuel line and pick up these pumps will support a LOT of horsepower for a very reasonable price. Who cares if they make noise. At least you can tell they're running
Re: I hate my Holly fuel pump! [Re: slowpoke] #476675
09/22/09 08:43 PM
09/22/09 08:43 PM
Wisconsin
69 Road Chicken Offline
Wisconsin
IIRC, that Carter fuel pump has 1/4 female NPT fittings on it, not tube fittings. You need to put your own tube fittings on it. Local auto parts store should stock something you can use for your 3/8" line
Re: I hate my Holly fuel pump! [Re: 69 Road Chicken] #476676
09/22/09 08:48 PM
09/22/09 08:48 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I have a new Mallory pump sitting in the box waiting to replace my holley blue pump when it dies. It's got 8 years of street driving and it's still going strong. They are noisey, but reliable.
Re: I hate my Holly fuel pump! [Re: farmington] #476677
09/22/09 09:02 PM
09/22/09 09:02 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
That was many years ago.
His car is a street car, the noise sucks.
Almost any mech pump will do the job for most street cars.
69 Dart 440 is right on.
Re: I hate my Holly fuel pump! [Re: farmington] #476678
09/22/09 09:25 PM
09/22/09 09:25 PM
So Cal
HealthServices Offline
Why would you even post that?
So Cal
What? Turn off the friggen fuel pump, I can't hear you!
Allen Here's a novel idea, let's not throw a bunch of parts at the car hoping it will fix the problem and instead spend a little time diagnosing it first. Life was a little easier when I was just a wrench.
Re: I hate my Holly fuel pump! [Re: 69 Road Chicken] #476679
09/22/09 11:30 PM
09/22/09 11:30 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
It does seem to work OK, but I can hear it clearly over my exhaust, and I'm running headers and some fairly loud flowmasters!!! The only bonus I can see running the electric (if a mech can indeed flow enough fuel to keep my motor happy) is the ability to prime the carb after it's sat for a while.
So is the consensus that the Carter (with it's 1/4 inch bottleneck female inlets) could handle this motor or should I go w/ one of the other's recommended??
Thanks for the replies!!
Re: I hate my Holly fuel pump! [Re: slowpoke] #476680
09/23/09 12:04 AM
09/23/09 12:04 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The nice thing about the Holley is that when you turn it on you know when the bowls are full 'cause the tone changes.
Re: I hate my Holly fuel pump! [Re: Stanton] #476681
09/23/09 01:18 AM
09/23/09 01:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Electric pumps are also better to fight vapor lock in hot area's. My buddies 68 Cuda 383 used to vapor lock on very hot days but never a problem when we installed an electric pump. The fuel is under pressure with the electric pump vs fuel under vacum being pulled up to the mech pump. I will take an electric pump any day over the mech pump. My sons holley red pump is 12 years old and still going strong and mine is 3 years old. Ron
Re: I hate my Holly fuel pump! [Re: slowpoke] #476682
09/23/09 01:22 AM
09/23/09 01:22 AM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Its not for 1/4" fuel line. Its 1/4" NPT
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: I hate my Holly fuel pump! [Re: 69L78Nova] #476683
09/23/09 08:48 AM
09/23/09 08:48 AM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
I understand that, my question is I've got a 3/8" pickup and line all the way to the carb and w/ the Carter, unless I'm missing something, it chokes down to 1/4" in and out of it. Seems like a mismatch, but I do see a lot of performance cars using them... The Holly mech uses 3/8 inlets and outlets I believe, but I don't know anyone who uses it. Hmmmmm.
Re: I hate my Holly fuel pump! [Re: slowpoke] #476684
09/23/09 09:04 AM
09/23/09 09:04 AM
Az
Crizila Offline
Crizila  Offline
Az
I went through two of those pumps ( the first one leaked ). Yes, they are 1/4" NPT in and out. Mounted mine by the gas tank and ran a 3/8" line to a single 750 Demon. At the time my small block was making about 425HP. The pump would not keep the carb full through a full 1/4 mile pass. It would run out of fuel just before the lights. Went to a Holley HP150 geroter pump and I now go through the lights with 3-4 psi ( making considerable more HP ) . Just my experience, but I will never buy another vane pump. They're for kids!
Fastest 300
Re: I hate my Holly fuel pump! [Re: Crizila] #476685
09/23/09 09:12 AM
09/23/09 09:12 AM
Ansonia, CT
CJK440 Offline
CJK440  Offline
Ansonia, CT
Just get a Mallory electric, swap it in place with the holley and be done with it. Keep the benefits of an elec pump but not hear it growling.
I had one on my Duster. 444ci 11.43 @ 120mph with the 110 street/strip version. You'd hear it just a little when you put the key on but thats it.
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
Re: I hate my Holly fuel pump! [Re: CJK440] #476686
09/23/09 09:19 AM
09/23/09 09:19 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Mallory is a little pricey but worth it for the quiet street runnings!
Re: I hate my Holly fuel pump! [Re: Dodgem] #476687
09/23/09 09:25 AM
09/23/09 09:25 AM
I run the Holley black pump..loud yes,but i like it that way lets me know its on..
Re: I hate my Holly fuel pump! #476688
09/23/09 12:36 PM
09/23/09 12:36 PM
P
Paul_Fancsali Offline
P
You Run Flowmasters and you worry about a loud fuel pump???? Who cares at least you know its working as previosly stated and parts to repair are readily available. I get 7-10 years out of them and replace them keeping the old ones for spares etc.
Re: I hate my Holly fuel pump! [Re: farmington] #476689
09/23/09 04:25 PM
09/23/09 04:25 PM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Holley pumps work.
