Re: I hate my Holly fuel pump! [Re: Harley] #476690
09/23/09 05:19 PM
09/23/09 05:19 PM
an8sec70cuda Offline
On the Carter strip mechanical pumps, 1/4" NPT is the fitting thread size on the pump's inlet and outlet. This is NOT a restriction if you're running 3/8" fuel line. They are not 1/4" diameter ports on the pump. It's actually larger than 3/8" diameter hose.
A Carter mechanical strip pump (the 8.5 psi version) will feed your motor. I ran one for years on a 440 in my 'cuda that was running 11.40s at 117 mph. I "upgraded" to a Holley blue pump w/ -8 (1/2") fuel line and didn't see any difference in performance. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: I hate my Holly fuel pump! [Re: an8sec70cuda] #476691
09/23/09 09:05 PM
09/23/09 09:05 PM
Near Indy
slowpoke Offline OP
slowpoke  Offline OP
Near Indy
Thanks a9sec70cuda, that makes sense!!
Think I'll go with the Carter. It's one thing to make a little noise, but when someone gets in your car and asks if that's the "flux capacitor" making that awful noise (that's my son's smart-alecky buddy!), it's time for a change...
Re: I hate my Holly fuel pump! [Re: slowpoke] #476692
09/23/09 09:41 PM
09/23/09 09:41 PM
Overland Park, KS.
Joshs68 Offline
Joshs68  Offline
Overland Park, KS.
I know Labrat ran a holley mechanical pump in his GTX running low 11's. The carter mechanical is more pump than that.
Re: I hate my Holly fuel pump! [Re: slowpoke] #476693
09/23/09 10:16 PM
09/23/09 10:16 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
I ran a stock pump supplemented by a Holley Blue for years. Cruised around running off the stock pump,flipped the electric on for racing. Worked great.
Re: I hate my Holly fuel pump! [Re: forphorty] #476694
09/24/09 12:07 AM
09/24/09 12:07 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
another vote for a mallory pump.
I have two friends who had that new holley pump and it went out,
one froze up completely..I think that new holley is made overseas.
Re: I hate my Holly fuel pump! [Re: 70blackfish] #476695
09/24/09 06:08 AM
09/24/09 06:08 AM
wisconsin
kmfdm Offline
kmfdm  Offline
wisconsin
I have a Holley Blue Pump as well. I cut up an old rubber floor mat and used it as an insulator between the pump and the area its mounted too. Quieted it down quite a bit.
74 Dart Sport
