Re: M.T. ET Streets vs M.T. Drag radials
[Re: an8sec70cuda]
#475027
09/22/09 06:41 AM
09/22/09 06:41 AM
Posts: 2,936 Finalnd, Perkele
jyrki
Finalnd, Perkele
Good track = radials Marginal Track = bias ply. At lest that's my experience. The bias ply tires push the car forward even if they spin a little, while the radials really tend to loose the traction completely if they start to spin.
Plynouth VIP '67 TT IC EFI
[Re: blownzoom440]
#475030
09/22/09 02:50 PM
09/22/09 02:50 PM
Posts: 13,543 Marion, South Carolina [><]
an8sec70cuda
i just ran 16lbs but feel i need more heat in the tirei will try longer burnouts next time.
More air pressure. CHIP
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: blownzoom440]
#475033
09/22/09 03:55 PM
09/22/09 03:55 PM
My duster hooks best at 15 lbs...
#475034
09/22/09 03:59 PM
09/22/09 03:59 PM
an8sec70cuda
Mine likes 19.5 to 20 psi. CHIP
[Re: an8sec70cuda]
#475035
09/22/09 04:01 PM
09/22/09 04:01 PM
Triple Threat
Renton Washington
Mine are always set between 16 and 20, It will hook wherever, so I adjust rear tire pressure to adjust my reaction times.
#475040
09/22/09 05:41 PM
09/22/09 05:41 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
ET Street radials here...295/65's...best hook is 15.0 cold. 3700# Challenger 496 4600 convertor and 625#'s of torque. Anything above the 15 and it gets dicey as to whether it'll blow the tires off 20' out.
[Re: RonP]
#475042
09/22/09 06:35 PM
09/22/09 06:35 PM
I run 15.5-17 (hot) in mine depending on track. 325/50-15's
Ron, i love your car..
[Re: fattire]
#475044
09/22/09 08:58 PM
09/22/09 08:58 PM
Posts: 1,090 north cakalaky
instigator
north cakalaky
I would run my 295-65/15 MT radials down to 12 pounds.....1.30 60's...mid 5.60's at 128mph. My suspension appeared to seperate quite a bit out back with never picking up the front tires....maybe not enough weight transfer for the reason for such low psi..
65 Barracuda All aluminum Indy HEMI with some boost! COMING TO A TRACK NEAR YOU!
[Re: instigator]
#475045
09/22/09 10:35 PM
09/22/09 10:35 PM
superwrench
This is getting interesting. I say that I hook good at around 15 cold....just that I've never tried it lower than that because it seems OK at that pressure. So many others on here running up at 18 and 20#'s that it almost made no sense to go lower.....then sit back and complain about the crappy tires! I'm wondering if there's a little more 60' left in it if I try going down a tad more? It hooked hard at Pinks in Seattle, and seems good at our tracks here...but there's always that search for that "little bit more". One thing for sure though....I'll never run a bias slick again...the radials run the track so straight compared to a slick at 11#'s. Next year I guess.....
